vr6 brake servo 2 pin distance sensor wiring
hi, whats happening, quick question i got a vr6 turbo its a old obdi 1 type, what it is under the brake master cylinder, there is a 2 pin port, can you tell me what colours are the two wires from left to right. basically, behind the brake cylinder is the big black drum, and on that drum there is a 2 pin port in the middle called the distance sensor, some vr6 dont have if but early wons have, can someone please check if you can.
cheers from Manps
