shawn25 0 Posted March 22, 2008 Report Share Posted March 22, 2008 Has any one converted a standerd vr6 2.8 to a 4 motion engine?would my standard gearbox fit also how much hassle is it to convert my golf is a mk 3 2.8 vr6 highline 1995 Link to post Share on other sites
UnitedMotorsport 55 Posted March 22, 2008 Report Share Posted March 22, 2008 Your gearbx will bolt right up, use the VR6 clutch and flywheel. Link to post Share on other sites
shawn25 0 Posted March 23, 2008 Author Report Share Posted March 23, 2008 What about the wiring loom Link to post Share on other sites
Phat VR6 3 Posted March 23, 2008 Report Share Posted March 23, 2008 I think you would need to use the wiring loom, ECU, clocks keys, fuse box ect from the mk4. You might be able to run it off the mk3 VR looms and ecu but i donno to be honistOther thing you could do is use standalone ECU and leave the fuse box clock ect in from the VR but everythink I say is just a guess.it would be the same as doing a R32 convertion so your best bet is to find somone thats done it before Link to post Share on other sites
UnitedMotorsport 55 Posted March 23, 2008 Report Share Posted March 23, 2008 Have the immobilizer removed from the ECU, and install the MK4 loom and ECU. itll run perfect. Link to post Share on other sites
