vag com fault codes, what do these mean, whats bust??
hi all, used a mates vag com on my vr and these codes came back, now the car is running fine so would just like to know what these mean and what i should be looking at fixing under the bonnet. many thanks, rob
Address 01: Engine
Controller: 021 906 256
Component: MOTRONIC M3.8.1 HS V02
Coding: 00000
Shop #: WSC 01317
4 Faults Found:
00668 - Supply Voltage Terminal 30
07-10 - Signal too Low - Intermittent
00533 - Idle Speed Regulation
14-00 - Adaptation Limit (Add) Exceeded
00561 - Mixture Adaptation
15-00 - Adaptation Limit (Add) Not Reached
01247 - Activated Charcoal Filter (EVAP) System Solenoid Valve 1 (N80)
31-00 - Open or Short to Ground
Readiness: N/A
