toofunkyhouse 0 Posted March 9, 2008 Report Share Posted March 9, 2008 hi all, used a mates vag com on my vr and these codes came back, now the car is running fine so would just like to know what these mean and what i should be looking at fixing under the bonnet. many thanks, robAddress 01: Engine Controller: 021 906 256 Component: MOTRONIC M3.8.1 HS V02 Coding: 00000 Shop #: WSC 013174 Faults Found:00668 - Supply Voltage Terminal 30 07-10 - Signal too Low - Intermittent00533 - Idle Speed Regulation 14-00 - Adaptation Limit (Add) Exceeded00561 - Mixture Adaptation 15-00 - Adaptation Limit (Add) Not Reached01247 - Activated Charcoal Filter (EVAP) System Solenoid Valve 1 (N80) 31-00 - Open or Short to GroundReadiness: N/A Link to post Share on other sites
