What version of VAG.com have i got?
http://www.ross-tech.com/Merchant2/merchant.mvc?Screen=CTGY&Category_Code=VAGCOM
$249 for the interface and software licence. With your cable you can get the licence only for $99. Version 409.1 is all you're ever going to need. If you just want it to clear fault codes stick with the freeware version you have (which is the latest you'll be able to use with your cable anyway).
Hope this helps - all the info is on the web if you are bothered to look for it ;)
