patpong_pete 0 Posted February 18, 2008 Report Share Posted February 18, 2008 help guyscar starts ok but sounds like its missing mis-firing running lumpy on 5 not 6 ?????so what to do next i know most will say just get it on VAG Com !1 check MAF give it a clean with carb cleaner2 plugs and leads3 coilpack (check for sparks)4 crank sensor 5 lambrada sensor (this is just for emissions or cat)thanks for any help and advice pete Link to post Share on other sites
patpong_pete 0 Posted February 18, 2008 Author Report Share Posted February 18, 2008 how long should spark plugs last? Link to post Share on other sites
hopefulVR6owner 0 Posted February 18, 2008 Report Share Posted February 18, 2008 plugs should last at least the service length but have been known to get the odd faulty one. for what it costs, if there overdue a change just aswell replace them!MAF wouldnt cause a mis fire as such just poor running and up and down on the idle and no guts on acceleration! i think your pretty much on the ball with your sparking system once you get so far back as the coil being ok then maybe start looking at injector or head gasket. Link to post Share on other sites
hopefulVR6owner 0 Posted February 18, 2008 Report Share Posted February 18, 2008 i dont mean replacing the objects obviously but just checking them. also same as MAF sens. the lambda shouldnt cause a mis fire. i may be wrong but havent come across these sensors just affecting one cyl. Link to post Share on other sites
patpong_pete 0 Posted February 19, 2008 Author Report Share Posted February 19, 2008 so plugs the platanuim ones r the same as normal NGK plugsbut last a lot longer where is the best place and price to buy ?euro or vw or gsm ???? Link to post Share on other sites
patpong_pete 0 Posted February 20, 2008 Author Report Share Posted February 20, 2008 help guyscar starts ok but sounds like its missing mis-firing running lumpy on 5 not 6 ?????so what to do next i know most will say just get it on VAG Com !1 check MAF give it a clean with carb cleaner2 plugs and leads3 coilpack (check for sparks)4 crank sensor5 lambrada sensor (this is just for emissions or cat)6 fuel relay fuel filter thanks for any help and advice pete Link to post Share on other sites
