jeru 0 Posted December 6, 2007 Report Share Posted December 6, 2007 hi guys, i spoke to you guys about a week ago about my vr6 not driving well (its pulling all over the place) and when i had to brake hard the other day, it was darting all over the road, i recently had the brake discs and shoes changed, and a full service done to the car when it began to exhibit these problems, so i took it for four wheel allignment, but its still driving the same, i have the schematic pictures of the before and after 4 wheel allignment that was done , is there anyone i could email the pictures to, that could give me some insight into whats needs to be done, thanksthe first picture is before, the second is afterhttp://img406.imageshack.us/my.php?image=beforecl2.jpghttp://img138.imageshack.us/my.php?image=afterwb9.jpg Link to post Share on other sites
Phat VR6 3 Posted December 6, 2007 Report Share Posted December 6, 2007 Your castor still out, But not by very much, Shouldn't realy make much of difference. I sure VW do a tool where you can slack the ball joint bolts off and reset the castor??? As i said you need to check your bushs on your wishbones!! Also wishbone bolt could be looseThen as kilo killa said a brake test from an MOT test center should be able to tell you if you have a sticking caliper/ Deterating brake pipe! Then can brake away inside and cause a blockage.If it pulls when accerating it could be a broken/ soft engine mount, Normaly the gearbox side, the fuild leaks out of themThese are the first things to check, After that im not to sure Link to post Share on other sites
