vr6 pulling when driving, and darting over road when braking?
hi guys, i spoke to you guys about a week ago about my vr6 not driving well (its pulling all over the place) and when i had to brake hard the other day, it was darting all over the road, i recently had the brake discs and shoes changed, and a full service done to the car when it began to exhibit these problems, so i took it for four wheel allignment, but its still driving the same, i have the schematic pictures of the before and after 4 wheel allignment that was done , is there anyone i could email the pictures to, that could give me some insight into whats needs to be done, thanks
the first picture is before, the second is after
http://img406.imageshack.us/my.php?image=beforecl2.jpg
http://img138.imageshack.us/my.php?image=afterwb9.jpg
Your castor still out, But not by very much, Shouldn't realy make much of difference. I sure VW do a tool where you can slack the ball joint bolts off and reset the castor???
As i said you need to check your bushs on your wishbones!! Also wishbone bolt could be loose
Then as kilo killa said a brake test from an MOT test center should be able to tell you if you have a sticking caliper/ Deterating brake pipe! Then can brake away inside and cause a blockage.
If it pulls when accerating it could be a broken/ soft engine mount, Normaly the gearbox side, the fuild leaks out of them
These are the first things to check, After that im not to sure
