baz8328 0 Posted September 4, 2007 Report Share Posted September 4, 2007 I have installed a HID headlight kit from ultra in my vr6however the lights are so bright BUT when i switch the sidelights on the HIDs flash for about 10 seconds then die !then i put my headlights on and they are fine !!PLease helpI have tested the voltage and i found thet when sidelights are on there is a small voltage goin to the HID s enough to make it flash but not enough to turn on !!Any suggestions ?would a in line fuse stop it !would a form of a resistor help PLEASE I AM PULLING MY HAIR OUT TRYIN TO FIGURE IT !!!!!!!!!!!!!!!!!!!!!!! Link to post Share on other sites
Goldie 0 Posted September 4, 2007 Report Share Posted September 4, 2007 somewhere there is a big resistor, with a yellow and yellow/blue wire on it, unplug it.i think its on the drivers side front chassis leg somewhere Link to post Share on other sites
baz8328 0 Posted September 4, 2007 Author Report Share Posted September 4, 2007 what does this do ??? Link to post Share on other sites
baz8328 0 Posted September 4, 2007 Author Report Share Posted September 4, 2007 what does this do Link to post Share on other sites
baz8328 0 Posted September 5, 2007 Author Report Share Posted September 5, 2007 would a capacitor work to stop the small voltage goin thru and the 12 v when needed goin thru Link to post Share on other sites
baz8328 0 Posted September 7, 2007 Author Report Share Posted September 7, 2007 woohoo sorted the problem i have took a 12v feed from the light switch and took it to the hids thus missing out the dim dip headlight circuit woooohoooooooooooooo Link to post Share on other sites
VDub_Steve 1 Posted March 5, 2009 Report Share Posted March 5, 2009 Can you talk me through what you done mate as i have the same problem Link to post Share on other sites
baz8328 0 Posted March 5, 2009 Author Report Share Posted March 5, 2009 ring me on 07921 519734 Link to post Share on other sites
xyber 1 Posted March 5, 2009 Report Share Posted March 5, 2009 wire the HID independantly from the lighting loom, use a heavier guage cable for live, direct to the battery and a heavy independant earth, then use the original loom to fit a relay so they will switch on the same, just they will have their own power, thats the only way you should really run HIDs as the initial jolt of power need to ignite them can easily overload the earth. I learnt this to my expense when I destroyed my Hella celis ring lightsVW lighting looms are notoriously crap, they take a long route and arent really beefy enough as standard Link to post Share on other sites
