heavy fuel
hi there(newbie) wonder if you can help.I have a 1997 golf vr6 with a fault code 00533.The car has become an alchoholic.I seem to get 100 miles to half a tank doing 75 -80 mph.I thought it was the airflow sensor as when i fitted an induction kit i accidently crushed the wiring.doh!Any one come across this fault code before.I have a list of things to check but they all seem to point at air leaks.Any help will be appreciated.
thanks.
thanks for the quick reply.i found the list of possible causes
1)idle air regulation limit exceeded possible causes:1)intake leak/blockage
2)throttle valve tight/sticking
3)idle speed controllactuator/position sensor faulty.
does any of this make sense?
