hella twin headlights removal/refitting
hey folks, done a search for this incase it had been covered before but couldnt see this.
I recently bought a VR6 with the hella conversion, however one of the lenses is smashed. I believe its the main beam lens (the one you can see the bulb through, without the fish eye on it). Basically the car is going for its MOT on saturday, i`ve managed to track down a lens from Germany of all places which should be here next week in time. Is anyone able to stick up an idiots guide to removing and refitting the replacement headlamp? I had a look on my gti today as it has the same lamps but not entirely sure how the broken one comes out. And i know if i go at it gung ho then it will be permanently busted!! Any help or instruction sheet would be greatly appreciated!!
thanks in advance!!
I've amassed alot of experience in removing the headlamps, the trickiest part is removing the grill but even that is pretty straight forward, yep the headlights themselves are just held in with 4 screws, easiest way is to use a 1/4" socket set.
