MagicIan 0 Posted July 2, 2007 Report Share Posted July 2, 2007 Righty, found a corrado for sale with a charged nugget in it but i know nothing about superchargers!It has a stage 2 setup with a Vortech V9F charger (i've heard these are the ones to have?) How many miles is a charger good for before it wants a re-build? And is it expensive?Thanks Link to post Share on other sites
xyber 1 Posted July 2, 2007 Report Share Posted July 2, 2007 direct from the warranty sheet that came with mine last thursclean and inspect oil feeds and do oil change every 3000 miles with OE oilplug every 8-10000filters at normal intervalsgood thing with these kits is if you look atfter the engine (reg servicing, letting it warm up before flooring it etc) the charger will keep itself sorted, so long as it is getting a good supply of clean oil.id imagine they will go on and on until its evident that its on its way out( bearings noisey, running probs etc)ps use optimax or other hi octane fuel aswell, 50-50 mix of g12+ coolant and if it hasnt got one a neuspeed low temp thermostat to keep things coolernot sure about rebuilds, bearing will be pricey though Link to post Share on other sites
MagicIan 0 Posted July 3, 2007 Author Report Share Posted July 3, 2007 Nice one thanks mate!Anyone else got any beans to spill? Also, how much are schrick inlet manifolds? and 268 cams? Are these the charger specific ones? Link to post Share on other sites
xyber 1 Posted July 3, 2007 Report Share Posted July 3, 2007 schricks are good with a charger once you set them to activate 500rpm (3000rpm instaed of 3500)lower that it normally does, just flick a few switches as per instruction manual, they are about £1300 but they pop up second hand a fair bit or group buys are good to look out for, i want one at some point268 are abit to big a profile for a charger i think, I think a few use 248 (?) but ive heard that stock cams are pretty good for chargers anyway, if you did want cams dougherty racing ones are good and about £210 and i think he may possibly do a model for s/c vr6s specificallyI would say tho if you are thinking of going mad on engine goodies mate sure the cooling is spot on first, just to protect your investment (oil cooler, water injection etc) Link to post Share on other sites
MagicIan 0 Posted July 4, 2007 Author Report Share Posted July 4, 2007 schricks are good with a charger once you set them to activate 500rpm (3000rpm instaed of 3500)lower that it normally does' date=' just flick a few switches as per instruction manual,[/quote']eh? Whats this about then? Is this cam or manifold related? Sorry if this is a stoopid question but i am a charger virgin! :$ Link to post Share on other sites
craggsy 91 Posted July 4, 2007 Report Share Posted July 4, 2007 schricks are good with a charger once you set them to activate 500rpm (3000rpm instaed of 3500)lower that it normally does' date=' just flick a few switches as per instruction manual,[/quote']eh? Whats this about then? Is this cam or manifold related? Sorry if this is a stoopid question but i am a charger virgin! :$ Its about the manifold. Easy to reset Link to post Share on other sites
