Kangerooing vr
Guest vrrobbie
Please help im new to this forum need to get my vr sorted before something bad happens, i own a mk2 vr6 donor engine was from a j plate mk3 dizi engine obd1.
I have a little problem, every time the engine comes to idle at a juction or something and u go to pull off again the car starts to kangaroo, its not a miss fire, its like it cuts the power to every thing like turnin the ignition off really fast, and its bad i've nearly nutted the window screen a few times if u keep ur foot planted, to stop it from doin it is to dip the cluch and let the engine idle and then it will be ok, till u have to stop again, it doesent do it all the time. my freind's mk3 vr does it aswell same engine spec so was thinkin it must be a common fault, i have checked the little things, i been told its poss the engine loom, but just wanted to know if this has happen'd to anyone else or some one u know before i start to change the loom???? Thanks Robbie
Never heard of this mate, very strange. Obviousy we all know that cars kangeroo when someone can't drive properly due to clutch control, you can obviously drive so i would imagine that its something wrong with the clutch ?? that would be my first thought, difficult to say without seeing it happen though.
Good luck with it anyway.
Dave
