adam_christie 0 Posted November 12, 2006 Report Share Posted November 12, 2006 Hello again! As you may have read, I've bought my first ever VR6, which had an oil problem (which is now sorted), a leaky radiator (which has been replaced, pics etc to come soon), and now seems to be running fine, however there's a real whiney buzz coming from the fuel tank/boot area. I know on a MK2 GTI there's an in-tank fuel pump which can make a pretty awful racket, but is there an in-tank fuel pump on the MK3 VR's aswel? I've had a quick look on Euro Car Parts and all I can find is an "Electrical fuel pump" priced at 113 quid!!! Any ideas? Cheers!Adam Link to post Share on other sites
matth76 1 Posted November 12, 2006 Report Share Posted November 12, 2006 Hi mate.If you had all these problems before you bought it I would have walked away. Not worth the risk. Anyway I would get a full check over by The Phirm or Stealth - they will tell you straight away what the buzzing sound is and check your car is ok. Both are the best in the uk (I wouldn't take it anywhere else) for vr's and same price as a local garage but far far more experienced than a main dealer. Stealth has a rolling road so can also dyno your car and make sure your power curve is nice and smooth which is what it should be if everything is in good order with your bottom end. If it is your fuel pump I would drive fairly easy (keep it under 3k revs) until fixed otherwise serious damage can be done. Let us know how you get on mate. Good luck. Link to post Share on other sites
stockers 1 Posted November 13, 2006 Report Share Posted November 13, 2006 the fuel pump is in the boot floor ( a round disc that is bolted down under the carpet) it will buzz on ignition and continue to buzz, this means its working, if you have no power loss or running problems i don't think you have a problem. if it stops buzzing then its knackered.the load buzzing may be indicating the pump could be on the way out, so if you suddenly get any running issues that would be your first place to check. Link to post Share on other sites
stockers 1 Posted November 13, 2006 Report Share Posted November 13, 2006 the fuel pump is in the boot floor ( a round disc that is bolted down under the carpet) it will buzz on ignition and continue to buzz' date=' this means its working, if you have no power loss or running problems i don't think you have a problem. if it stops buzzing then its knackered.the load buzzing may be indicating the pump could be on the way out, so if you suddenly get any running issues that would be your first place to check.a dodgy fuel pump won't harm your car, it will run real bad then won't run at all as there will be no fuel getting to your engine.[/quote'] Link to post Share on other sites
mk3anni 0 Posted November 13, 2006 Report Share Posted November 13, 2006 The fuel pump is not in the boot floorThe fuel pump is in the tank. The access hatch is in the boot floor, remove this and you can see the top of the fuel pump sitting in the top of the fuel tank. Link to post Share on other sites
adam_christie 0 Posted November 13, 2006 Author Report Share Posted November 13, 2006 Well, it's virtually in the boot floor.......Anyway, am I right in assuming that it's the only fuel pump in the car? TaAd Link to post Share on other sites
stockers 1 Posted November 13, 2006 Report Share Posted November 13, 2006 The fuel pump is not in the boot floorThe fuel pump is in the tank. The access hatch is in the boot floor' date=' remove this and you can see the top of the fuel pump sitting in the top of the fuel tank.[/quote']that is splitting hairs and quite irritating to be honest, obviousely the pump is in the tank but as you can't see the tank but you can see the boot floor it seemed sensible to use the part of the car that can be seen. Link to post Share on other sites
mk3anni 0 Posted November 14, 2006 Report Share Posted November 14, 2006 Oh well, I'm sure the irritation will pass you by soon enough.Instead of bitching how about you answer his question...oh don't worry i'll do it for you.Yes it is the only pump in the car! Link to post Share on other sites
adam_christie 0 Posted November 15, 2006 Author Report Share Posted November 15, 2006 Cheers mate! Link to post Share on other sites
