lateral acceleration sensor
  • 1 month later...
Guest rossinator
Fault may not be the sensor itself, but the geometry of the car may have changed and the ecu needs altering. You need to run some diagnostics and reset the zero position of the above sensor, which should be done whenever wheel alignment is done. If your unlucky enough the engine management comes on too...
