About maftec
Banbury oxon
Seriously.... can kitchen foil reflect engine bay heat soak
maftec replied to The Monk's topic in Engine Tuning
Hay Munk, I thought it was just me making my car faster with offcuts and snot. I made an air ram by removing head lamp glass cutting hole in back of it. Then used an old air filter box ( cone like shape) which i riveted to the headlight, Fixed that to 8" of 110mm soil pipe ( domestic poo pipe, new and unused i may add). Then i had the quandri of reducing down to sweetly lip on to the MAF sensor. After turning the old workshop upside down i found an old roadcone. PERFECT. Cut it to the correct appature then cut in to the ends to make flaps then jubilie cliped on to the MAF -
Obd1 N/A, stock engine and box, Moded exhaust, stiky tyres, 60 FT; 2.33 1/8; 9.63 1/4 mile; 14.87 Terminal speed 93.8 MPH
Has any one taken any weight off there flywheels?. I think there about nine Kilos standard. What does anyone think. For track use only. Cheers
Even though mine is for the track only, I just built a 2.5" straight through pipe from standerd header, which does a ninty bend and side exits in front of the n/s/r wheel. Was a bit too loud so where the Cat was i put in a cheep stainless straight through muffler to give it a better tune. Sounds and goes like greased weasle shit. However if you done this and put a cherry bomb tail as side exit i think this would be well in linits and sound the Dogs swingers. Good luck.
Good reading bungy, thanks. Wow what a fella jim rocks. Has inspired me . cheers fellas.
Good point well delivered. Do you think a Big shot of NOS would get it somwhere close with some heavy thowing in the stingers of all the unnesserary weight?
nice one chaps, found it. any tips on getting a 2.8 in to the 13 seconds with only a few hundred quid? Or am i on another planet
Hi new to the club and wondered if there is a parts for sale section like Volkszone? cheers Maftec
