Hi...what you need to do is attach a flexible pipe to the bleed nipple, get a clean jar and 1/3 fill it with new clean brake fluid (same stuff you are going to top the clutch resovoir up with) submerse the other end of the flexible pipe in the jar, make sure the resovoir is at max and loosen nipple and push clutch pedal to the floor slowly and while pedal is flat to the floor do the nipple up and now release pedal, check reovoir fluid and top up to the max again and repeat until all air is expelled, obviously to do this properly you will need a helper or buy one of them one man bleed kits made
