Tiny12
About Tiny12
    Bromley
  1. yea I just worked out the measurements on the ruler and there is nothing in it is there!!! what type of width/profile should I go for a subtle stretch?? (on a 17 inch wheel with 7 width!)
  2. thanks dru, i belive i have one coming!! will keep an eye out for a bently one for the future!
  3. I have been offered a set of rims which are 17x7, and some one else has offered me a set tyres which are 195x17x45 the guy offering me the tyres recons that they will go on ok with a "nice" stretch, but not a “silly stretchâ€â€¦is this true? Or am I getting turned over here?
  4. Hi Hi, Any one know if I can get a Haines manual or similar for my 95 mk3 VR6…I need to replace the passenger side wheel bearing!
  5. i think i may have the same problem....from the sensors on the top of the oil filter housing...i thought it was the nut on the sensors which was loose but they are both tight as poss.
  6. Hi all, I got home last night after a wee run to the gym, and there little trickle of oil underneath the car on closer inspection I found it (the oil) to come out of the top of the oil filter housing, one of the leads into the top (the left hand side lead looks to be the culprit as it is covered in oil and the right hand is bone dry/clean). I didn’t fix it last night as the engine and oil was still hot, however I will attempt a fix this evening. from what I can see it looks as though the nut on the left hand lead may be lose as the oil looks thickest around the nut. Do these leads into the
