ssaunders
Members-
Days Won
14
Content Type
VR6OC News
Website Content
Profiles
Forums
Calendar
Gallery
Store
Collections
Community Map
Everything posted by ssaunders
AUE VR6 24v turbo - in depth information required
ssaunders replied to VR6TUK's topic in Engine Tuning
Hi mate, have a look round the forum there are plenty of threads on Turbo builds with lists and a lot of input from the other members. The Ecu you have will run a turbo, again lots of threads here and on other forums. Good luck on the build. S -
last ones i got were from main dealer
Standalone Haldex controllers
ssaunders replied to ssaunders's topic in I.C.E, Security an Electrical
Thanks for the replies, I have been in conversation with Wilco at DB, I wanted someone who has tried one or more on the market for real world use ability. Do I need to spend 900 euro on one that has all the bells and whistles where a 500 euro one will do? cheers steve -
Hi all, I need to get a standalone controller for my 4 mo conversion. Who has one and what make is it? I want to control it inside the cabin. Crc performance do a good one but it's a bit lumpy, is there a standalone Ecu that can do haldex? Thanks for looking. Steve
Mounting points should be the same so ok to use original screws
Usual service items plus Chains and guides, water pump. Did you see it running? If you can check the compression, I think it's the 6th cylinder that can wear. Valve stem oil guides.
I've got the Dubsport Corrado 4x4 Turbo from sept 2004 PVW
new ones here - http://www.ebay.co.uk/itm/NEW-VW-GOLF-MK3-Rear-Cargo-Cover-Shade-Tray-Cover-Power-Speakers-SIGNAT-2X120W/132100509869?_trksid=p2047675.c100013.m1986&_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D40656%26meid%3D26244dc25cee42e3bdf715db5305a4c9%26pid%3D100013%26rk%3D1%26rkt%3D12%26sd%3D132100509869 WTF!! how much?
front crossmember bushes
ssaunders replied to rsweeney's topic in Wheels, Brakes, Suspension and Steering
£30 delivered. http://m.ebay.co.uk/itm/112333645337 Bit of spare metal though. -
Matty's Golf mk4 R32 Turbo 4 motion
ssaunders replied to matty.vrt's topic in Members Rides and Event Photos
hi, im currently getting my DRP rebuilt. here is a list of whats going in epytec reinforcement plate - https://www.epytec.de/en/engine-transmission-tuning/02m-6-gear-transmission/2937/vw-audi-02m-6-speed-transmission-gear-reinforcement-reinforcement-plate-golf-1-2-3-4-vr6-r32-s3 4th gear support - https://www.bar-tek-tuning.de/en/transitional-support-4th-gear-transmission-02m-02q Bronze sliders - https://www.bar-tek-tuning.de/en/02m-02q-bronze-sliders-gear-shift-fork also a quaiffe front diff solid shaft pressed into the input shaft to stop it bending modifie -
Nice Rocco. i have found that the epytec stuff is cheaper direct, the last stuff i bought from them took less than a week to arrive. Bar-Tek are reasonable as well. Besters on here does a short shift thats great, dont know if it will fit your scenario though. good luck with build. s
[SOLD] Quaife 6 speed for 02A/J
ssaunders replied to ssaunders's topic in Exhaust and Performance parts
SOLD -
ABS Pump My mate teves
ssaunders replied to Bu7tyboy's topic in Wheels, Brakes, Suspension and Steering
hi, i think it needs full vag-com to recode the pump. so its either main dealer or someone on here that can help. i also found this for Teves coding - http://www.houseofthud.com/cartech/abspump/ABSProcedure.html and it looks like you need the details from the old one and a few posts have said that the P\N must match, i dont know how true that is though. good luck steve -
As before £1200. My gearbox builder may have it but if it goes before he makes his mind up..... also up on Vw vortex, club gti, corrado net, motorsport sales and gumtree. Currently removed from broken (diff) box and needs as diff, case and new home. Thanks for looking Steve
welcome! looks lovely but we need more pics!
Hi, it can be a real pain to get the mounting bolts out which may need a mechanic. You should be able to loosen the engine mounts and jack the drivers side of the engine up to get access to it.
Hi, I have got a quaife 6 speed kit for 02a/j, it came from my old car where I fucked the diff. Spec is here https://shop.quaife.co.uk/quaife-vag-6-speed-synchromesh-gearkit (this is exc VAT) its currently in bits at my gearbox builder (HotGolf) ready to fit into a new box but I am going 02m so it's surplus to requirements. i want £1200 for the bare kit, or I have an old 02a I can send to Martin and have it put in with standard diff and full rebuild - £1700 or if some one has a case and diff send it to him for build, POA. thanks for looking steve
Timing chains!!!??? Late and early??
ssaunders replied to F16XER's topic in Engine Maintenance and Problems
Hi, too late now but possible use for reference 2.8 12 valve engine i believe should be code AAA********** the chains change at AAA217000 upto is double after is single. s -
Hi All, if anyone is interested i have come across a few posts where it has been said you can use an Audi part instead P\N- 444823531A is for the RHD (posts ref 443823531A LHD) RHD drive ones are £35 inc vat LHD drive ones from Ebay US - £66 for 4 http://www.ebay.co.uk/itm/Audi-100-200-5000-80-90-S4-Cabriolet-Set-of-4-Hood-Release-Cable-Gemo-443823531A-/151898111417 post i reference is here - http://forums.vwvortex.com/showthread.php?6090849-Looking-for-a-cheap-OEM-Hood-Release-Cable-Check-out-VAG-Part-No-443-823-531-A anyone fancy a group buy? s
Yes please Dave, I have sampled the awesome short shift, what other goodies do you have?
dont think he has moved to Germany?
preempt it with this Pete. http://www.ebay.co.uk/itm/like/170576918629?lpid=122&chn=ps&adgroupid=40176066202&rlsatarget=pla-279594462905&adtype=pla&poi=&googleloc=1006621&device=c&campaignid=738210941&crdt=0 its on my to do list when i eventually get the car back.
Hi All, currently getting this https://shop.quaife.co.uk/quaife-vag-6-speed-synchromesh-gearkit rebuilt into a 02A box, i wont be using it in my new install so gauging interest, the box will have new seals and bearings etc so whats it worth? cheers steve
hi All, just found this and didnt know if anyone has had any experience with them? basically it looks like a plate to fatten out the flywheel connection to use a 228mm clutch rather than the 240mm on a 02m conversion. https://www.epytec.de/en/special-offers/4270/vw-flywheel-corrado-passat-golf-02m-6-gears-gearbox-adapter-vr6-conversion cheers steve
