About STEWVY
Hadleigh, Suffolk
so how wide is a fair compromise also i have a set of audi a6 (7 wide) alloys but im concerned bout fitment after pcd adaptors
thank for fast reply. they are gonna be golf spacesavers
hi ppl i'm gonna order some banded steels so any ideas how wide i can go but keepping MOT worthy ( no wheel poking out of the arches) thx in advance
will they fit then? will they stick outta the arches?
sweet the ET is 45 Rim width 7J and i can get any size pcd adapters 20/25/30 mm thanks for any help
hello guys if i put the et(offset) thickness of pcd adaptors and rim width can any 1 tell me if a set of audi a6 alloys will fit my golf. i'm a little confused lol
thanks calico
thanks lads dint wanna fork out fork them and find out they dint fit so with a ET of 25 will they stick out of my arches ?
nope thats the ET stamped on the rims do it add the thickness of adaptors to "45" or subtract?
It twists on my 1994 obd1 i seem to remember when buying pads there are 2 diff types of caliper (mine have lockheed stamped on them) i dint buy the wind back tool either. 1. put the caliper in a vice 2. use a pipe wrench to turn the piston take ure time and dont touch the rubber with the teeth on the wrench (brake fluid in the discs cant be good) ONLY GRAB THE DIRTY OUTSIDE PART OF THE PISTON, NOT THE CLEAN PART THAT SLIDES PAST THE O-RING IN THE CALIPER
they are 15 inch, 7inch wide i used the offset calculator in this forum and it says 8mm closer to the strut but smallest pcd adaptors i can find are 15mm and biggest are 35mm
has any 1 got wheels with an offset of 45 fitted to their golf using pcd adaptors? dont no if my new alloys will fit :-( thanks in advance
Audi rims? any1 got them
STEWVY replied to STEWVY's topic in Wheels, Brakes, Suspension and Steering
the ad said a4/a6 if i was any good at photoshop i'd have a go to see wot they'll look like -
ebay item 250499005211 i won a set last nite wen i logged on to ebay, searched vw alloys, and they popped up 1st in the list with 11seconds left !!!! £30 bargain theyre 5x112 so i need sum adaptors just wondered if any1 had them fitted so i could see them -
any1 got these on a mk3 golf? theyre 15 inch 7 inch wide 8 spoke with centre caps i have a pic but wont up load for sum reason i'll try again
