About markiemclean
Aberdeenshire
VR6 rear calipers
markiemclean replied to markiemclean's topic in Wheels, Brakes, Suspension and Steering
cheers for your help guys -
Can someone let me know if the back caliper from a K Plate VR6 will fit on my N Plate VR6. Cheers
cheers guys, ill give it a try once im finished work
Rear Drivers side Elec window went yesterday. There was a bang and when I looked the window was slightly down and wouldnt go back up. Tried both switches (dash and door) and they only put window down, not up. Motor is still working, can hear it but just wont put the window up. Not the best as my car is parked in town with black tape on it to make sure the window doesnt come down while im at work Ive read the other threads about the wires breaking but mine seems to be still getting power as the motor is still making a noise Any suggestions welcome, cheers in advance
i notice a few vr's with a heatshield between the engine and the induction kit. where can i get 1 of these rather than making 1 myself (lazy i know) cheers
hey guys and gals i need to replace the 1 way valve that feeds into the induction system and reservoir, part has split in 2!! great i see a lot of vr's with breathers on here, if i was to fit a breather where do i re-route the pipe etc that is there as standard? any help appreciated cheers
Hey guys, help NEEDED My MK3 VR6 is using a lot of coolant. It has done this since not long after i have got it but gradually this has got worse. It seems to be coming from the overflow in the header tank. I have changed the seal in the header tank cap, i have changed the cap from the older style black one to the newer blue one and this hasnt helped the problem. any suggestions? Cheers
Advice on fitting shocks??
ill let you know what condition theyre in once removed, fingers crossed should be saturday. will keep you updated -
I bought and fitted my 17's yesterday, shocks ordered and should arrive by weekend!! Are shocks easy to fit, any tips and advice would be much appreciated. Cheers buds
