CENTRAL LOCKIN UP SHOOT CREEK>>>>>
Hi everybody Can someone HELP on problem...Golf vr6 highline has occured fault with central lockin only yesterday.goes to get in,and got to use the dam key.alarm works ok,no noise coming from c/lockin pump in boot at all.was replaced 4 months ago,checked terminals and was ok.dont know if powers gettin there.battery is a month old,and had it tested to make sure.when i start the car the clock goes to zero.any ideas....cheers..........justo.
Hello. More than likely its a fuse check youe interior light and if it still works if not its either the bulb or the interior light fuse i think its number 23 but cant remember. The central locking, clock and interior light all run off the same fuse. Good luck :! :!
