Guest Suti Posted March 19, 2006 Report Share Posted March 19, 2006 Hello,I'm from IstanbulI have AAA OBD1 engine on my Ibiza with83mm JE forged pistons (~2940cc)+1 mm Ferrea exhaust and intake valves268 Schrick cams,titanium retainers and valvespringsported and polished cylinderhead10.4 comp. ratioSupersprint Headers60mm freelow exhaustRemapped ECUI dynoed my car and it gived 199bhp and 235Nmbut my car's AFR was around 15.5~17I have changed my injectors with 550ccnow my AFR is ~13 but my car gives 220bhpis it normal? Actually I was expecting more power, I thing there is a problemWhat do you think or recommend? Link to post Share on other sites
matchew 0 Posted March 19, 2006 Report Share Posted March 19, 2006 sounds like the person that mapped your car hasnt done it correct, as maximum power is made around 12.3:1 AFR, id say you need to get it mapped again by some one who knows what theyre doing, aslo you dont need 550cc injectors. Link to post Share on other sites
Guest Suti Posted March 19, 2006 Report Share Posted March 19, 2006 sounds like the person that mapped your car hasnt done it correct' date=' as maximum power is made around 12.3:1 AFR, id say you need to get it mapped again by some one who knows what theyre doing, aslo you dont need 550cc injectors.[/quote']the man who mapped my car told me that my injectors are not enough, thats why I changed my injectors,which company do you recommend? Link to post Share on other sites
IbiVR 0 Posted March 19, 2006 Report Share Posted March 19, 2006 the 550 injectors you have will give you enough fuel for over 600bhp. you dont need them on a na motor! Link to post Share on other sites
Guest Suti Posted April 2, 2006 Report Share Posted April 2, 2006 hello, It's me again I found an interesting thingas ı told you before my AFR was around 15.5~17I'm pull out my battery cable and wait for ~30 seconds then I pull in my battery cable, my AFR goes ~12-13 and wheel spinning at 1st 2nd and 3rd gear (that is very enjoyable)After few minutes or kilometers my AFR comes back to ~15,engine gives G68 fault code, with VAG-COM I clear all faults but my car has still ~15 AFRafter that, again I remove my battery cable and wait than again attach my battery cable, AFR comes to ~12I couldn't solved it Can anyone help me? Link to post Share on other sites
