532nm Green Dot Laser Alignment
In various precise and accurate dot projection at different work distances, including close distance, long distance and other hard reaching places etc, it is operating easy and quick with a high brightness device, such as a high brightness device of 532nm green dot laser alignment. It is generating highly visible and bright green laser light at several miles far away. Under operation with good thermal emitting and constant power source supply, not limited by any working environments and hard places, this 532nm green laser diode module just makes sure of easy reaching, long lasting and highly stable dot projection for all application fields effectively.
This green dot laser alignment is an industrial stabilized dot measuring device. Owing to its wide range output power of 5mW to 100mW, in order to assure highly visible and bright green laser light emission at various work distances, it just gets proper use of different operating voltage of 5V, 9V 1000mA AC/DC adapter. Any time it makes long lasting dot projection within 8 to 10 hours per day, this green laser module just leaves enough space and time for tube cooling down, and assures highly reliable and stable dot emission as long as 25 meters and other high lighting working occasions as well.
For the most important of all, any time 532nm green dot laser alignment is operating with special use of extending electric wires, within the maximum installed distance of 3 meters, it assures the most convenient installation, and the easiest reaching of green reference dot projection onto any vertical or horizontal surface. On condition that it gets increasing temperature and serious electric current impact, it still gets no effect by real working environments, but still keeping work with the most stable dot indication for industrial precise dot measurement, drilling system, laser marking, laser engraving, high tech and lab experiment work etc.
On basis of the most compact size tube design of 16mm and 26mm tube, this 532nm 5mW to 100mW green dot laser alignment enables easy carry and operation. It makes noncontact and no barrier dot indication onto any raw material surface. After correct use of output power and easy adjustment of both laser beam focus and dot emitting direction, after immediate green laser light concentration, this green alignment laser gets increasing accuracy and brightness dot measurement in distance. When users are taking laser safety measure and wearing correct laser safety glasses, without any eye exposure to laser beam aperture, it just brings users the most secured and the most convenient dot measurement perfectly.
Reply to this topic...
