ai07o00420 0 Posted April 29, 2022 Report Share Posted April 29, 2022 Hi guys,I have been reading for a while everywhere.The setup is VW Bora vr6 2.8 24v 4x4(Haldex) gt35 Twin scroll 500WHP Target LPG+Gasoline Megasquit ECUDaily will run on 360WHP since it will use LPG(F this fuel prices) and that's the limit on the current LPG injectors (the biggest I found)It must be a daily driver and will be smashed from morning until evening and must NOT Brake (Often)Solutions :1. I would like to put Diesel (130PD/150PD from 1.9tdi) gearbox with Reinforced Fork(I heard they brake) BUT-The bolt pattern of the VR6 housing is different and an adaptor plate is needed-If the inside of the diesel is moved to the vr6 housing will everything fit? did somebody actually do it?They claim it is possible but I can't find anybody who actually did it.2. Audi a4 2.7TDI Swap engines (TRANSMISSION ADAPTER PLATE, VR6 TO AUDI QUATTRO TRANS)- I can easily buy an a4 2.7TDI(Untill 2004) (that's the toughest Transimison since high NM in low RPM(I believe)***BUT how will all the dashboards heating windows ETC work?3. Audi Quattro DIF/Gearbox into Bora with an inverted engine to Longtitudal positon-Did anyone actually ever do it?-Is this possible?Which solution is the most efficient and realistic?Thanks, guys! Link to post Share on other sites
