Hi guys wondered if u can help  i have a mk4 golf vr6 and i have a issue when the radiator fan comes on the radio turns off completely.  As if its been unpluged. Then comes back on when fan stops  i thought it may be the fan switch but it dident work  its got a new thermostat and temp sensor and cam  shaft sensor as a code. Came up as cam sensor  any help would be appreciated.  Thnx
Is the car running okay? Generally replace any sensors with codes but if theres too much current drop & a few problems at once like this, I'd get a multimeter & check the wiring/relay/currents before anything else for what they cost.
Most of the time it runs ok. But sometimes if i turn of the engine after driving say half an hour then turn it back on it splutters and cuts out untill i rev it i got a code for camshaft sensor high output  so i changed the bank 1 sensor but  still has that issue also   I will try with the multimeter and see what i find thanks for the advice
