Harry-vr6 30 Posted October 14, 2020 Report Share Posted October 14, 2020 Picked up a bit of a shed not so long ago which I plan on restoring, its a 3 door mystic blue vr6 with about 109k on the clock. Needs a fair bit of work. both sills need repairing (rust/corrosion) jacking points (rust/corrosion) Hole in the floor, done by previous owner but a poor job as you can see so will be doing this again Possibly a full respray as its had a poor paint job Few bits under the bonnet need attention Heater control only works on 3/4 (ANY TIPS WELCOME) Driver side electric window doesn't work (ANY TIPS WELCOME) Central locking system doesn't work (ANY TIPS WELCOME) Slight blow from the exhaust Wires hanging out from under dash Front passenger wheel seems like its on a angle Tracking is out God knows what else I may find lol VR6 Supercharged and VR6Pete 2 Quote Link to post Share on other sites
Harry-vr6 30 Posted October 14, 2020 Author Report Share Posted October 14, 2020 got it booked in for the welding job so I made a start by removing the seats, carpet and few of the rubber seals. Hoping once its done i may use some sort of sealant directly on the floor to prevent any further rust issues . Any recommendations are welcomed. VR6 Supercharged 1 Quote Link to post Share on other sites
Harry-vr6 30 Posted October 14, 2020 Author Report Share Posted October 14, 2020 Some flooding going on here, damn it stank! VR6 Supercharged 1 Quote Link to post Share on other sites
Harry-vr6 30 Posted October 14, 2020 Author Report Share Posted October 14, 2020 Quote Link to post Share on other sites
Harry-vr6 30 Posted October 14, 2020 Author Report Share Posted October 14, 2020 Driver side sill is a mess, will be ordering both sills in the next couple of days, tried many places and they seem to be out of stock. Some are overpriced too. Will be getting inner and outer sills. Rears seem fine as they where done by the previous owner doesn't look too bad back there but again i will have a proper look as there seems to be many surprises lol.. VR6 Supercharged 1 Quote Link to post Share on other sites
Harry-vr6 30 Posted October 18, 2020 Author Report Share Posted October 18, 2020 Sills ordered just waiting on delivery. In the mean time i investigated why the driver window was not functioning. Turns out the glass was not even fitted to anything and the window motor wire was fullOf water. Gave it a clean and fitted the glass in. Seemed to be working fine hopefully thats one thing out the way. I also removed most of the rubber/foam that was soaked. Lots of loose uncovered wiring was found under the glove box so will get on to this next. Passenger side door was filled with water i noticed there was a lot of gunk and glass blocking the drainage holes which resulted in the water building up. I drained the water, however still need to remove all the crap stuck in there. VR6 Supercharged 1 Quote Link to post Share on other sites
Harry-vr6 30 Posted October 20, 2020 Author Report Share Posted October 20, 2020 So I cleaned up the passenger door and cleared the drain holes all looks good there now. I started on sorting all the wiring under the glove box out and thought whilst I'm there i should look in to then heater blower. Looks like some botched wiring job here. Will be getting a replacement blower and resistor. Noticed there was some water so I investigated further. Ended up checking the pollen filter and found gunk and leaves and the filter was drenched. I cleared this up gave it a good wipe down and made sure the water drainage channel was clear. I ended up using some silicone before fitting the pollen filter housing back on. Quote Link to post Share on other sites
Harry-vr6 30 Posted October 20, 2020 Author Report Share Posted October 20, 2020 VR6 Supercharged and j4ygt 2 Quote Link to post Share on other sites
Harry-vr6 30 Posted October 30, 2020 Author Report Share Posted October 30, 2020 Been finding somePuddles on the front passenger and driver side. IKnow the sealsOn the doors are shot including windows, which will be replaced soon but water was entering from behind the fuse box and alsoOn the passenger side where the rubber bung is behind the heater blower. After investigating further i found that the live (red) wire for the amp was fed through this rubber bung at the top therefore water was pouring in. I removed the wire and pushed it through the bung which then sealed properly. I applied some silicone around it to make sure. Hopefully this is now resolved. As for the driver side i checked the bonnet release cable rubber under the scuttle panel. It seemed pretty good but i gave this a good clean and sealed it up with some silicone. It was raining and i never noticed any water in the usual areas so fingers crossed this is sorted. Moving on i checked the rear of the car. Removed the sound proofing and carpets to check the spare wheel area. Carpet was wet so after checking the area i decided to remove the rear lights to check the seals/gasket. WOW! one screw on each light and water was definitely coming in from the passenger rear light. I gave it a good clean and then used new seals/gasket with some silicone around the edges. Also got all the nuts and tightened them up as before there was 1 nut on each light that seemed only hand tight lol. VR6 Supercharged and J4Y VR 2 Quote Link to post Share on other sites
Harry-vr6 30 Posted November 2, 2020 Author Report Share Posted November 2, 2020 Getting a little frustrated now with this project, seems like i find more and more issues as i go along. I have 2 spots where water os entering from. 1 - water coming in from the pollen filter housing although I sealed the bottom it seems toBe getting inside the housing. 2 - now this is really f@@@ing with my head, seemsLike its entering from behind the fuse box area, i placed some tissue in the area and after a day it's soaking wet. anyone who reads this and has an idea please do let me know. I have posted pics below Quote Link to post Share on other sites
Harry-vr6 30 Posted November 12, 2020 Author Report Share Posted November 12, 2020 Getting the car prepped for welding. Loads of work to be done, i almost gave up and wanted to just get rid. Never dealt with such a pile of shite before lol. Stuck a new battery in today so i can get it over to the welder tmrw. 90% sorted all the water leaking inside issues. Got a garage unit sorted so once its back it will be stored in a garage, this way i can start on clearing up the surface rust and treat it before painting with under-seal. Quote Link to post Share on other sites
Harry-vr6 30 Posted November 16, 2020 Author Report Share Posted November 16, 2020 Got the car to the welder was a fun drive with holes in the floor and air coming through! Best part no fan lol froze my back side off. Lots of work needs doing so I told the welder no rush. In the mean time i had my waterpump replaced on my mk6 golf Quote Link to post Share on other sites
Harry-vr6 30 Posted November 22, 2020 Author Report Share Posted November 22, 2020 Car is still with the welder, the more he digs the more he finds. Im shocked how it passed an MOT i will be looking in to this. On the upside Atleast the car will be rust free Quote Link to post Share on other sites
Harry-vr6 30 Posted December 18, 2020 Author Report Share Posted December 18, 2020 Well car is still with the welder, he has done his back in so has set me back. In the mean time im searching for some bits and bobs i need. Will update when i get the car back j4ygt 1 Quote Link to post Share on other sites
Harry-vr6 30 Posted December 22, 2020 Author Report Share Posted December 22, 2020 Quick update, popped over to see the progress of my car, one side almost completed then on to the driver side. the weld job done previously was a absolute joke lol il upload some pictures Quote Link to post Share on other sites
Harry-vr6 30 Posted December 22, 2020 Author Report Share Posted December 22, 2020 Quote Link to post Share on other sites
Harry-vr6 30 Posted December 22, 2020 Author Report Share Posted December 22, 2020 The previous weld job on the floor!! Im no welder but this must was a joke Quote Link to post Share on other sites
VR6CABBS 1,311 Posted December 27, 2020 Report Share Posted December 27, 2020 You’ve got your work cut out there mate but hold in there. I miss my old vr6. Currently having a big garage built in my back yard so I’ll most probably get another. Quote Link to post Share on other sites
VR6CABBS 1,311 Posted December 27, 2020 Report Share Posted December 27, 2020 Also check the rain well ducts for blockages too. Most leaks are caused because they become blocked so water comes in here there and everywhere. Quote Link to post Share on other sites
Harry-vr6 30 Posted December 27, 2020 Author Report Share Posted December 27, 2020 Also check the rain well ducts for blockages too. Most leaks are caused because they become blocked so water comes in here there and everywhere. Ye i have cleared this area, i also cleaned out the door jam drains, i did check the sun roof ones but they seemed clear. We did discover a hole in the drives arch so im hoping this will resolve the issue. Im hoping once its back i will remove the trim (A pillar) and have a look there, the issue is its coming from around or just above the fuse box area. Quote Link to post Share on other sites
Harry-vr6 30 Posted January 7, 2021 Author Report Share Posted January 7, 2021 Got the car back, lots of work done to it, so far its solid now no rust issues. Its dry stored now so At least its out the poor weather. I don't even have it in me to start work on it lol but i guess i will need to start on it. I think i will start by getting the new heater blower and new resistor in hopefully this will fix the heater blower issue i have (works on full only at the moment) then i guess its on to cleaning and degreasing the inside and start on some rust prevention paint. j4ygt 1 Quote Link to post Share on other sites
vr6freak 3 Posted January 8, 2021 Report Share Posted January 8, 2021 I have similar water issues in the front foot wells. Turns out to be poorly bonded in windscreen. So it will be screen removed and roof painted next week (some penny sized rust bubbles where the roof meets the screen) and hopefully the same windscreen bonded back in if it, doesn’t break!!!!!. I will post some pics. Quote Link to post Share on other sites
Harry-vr6 30 Posted January 8, 2021 Author Report Share Posted January 8, 2021 I have similar water issues in the front foot wells. Turns out to be poorly bonded in windscreen. So it will be screen removed and roof painted next week (some penny sized rust bubbles where the roof meets the screen) and hopefully the same windscreen bonded back in if it, doesn’t break!!!!!. I will post some pics.Where about's did you notice water entering from? Mine seems like its coming from just above the fuse box area. Could possibly be trickling down sides and then ends up just above the fuse box. I actually read this somewhere, i did enquire about a screen and a re-seal as i feel it could be just what you said! It does look as though someone has done a poor job on sealing the windscreen especially on the driver side corner. I might just get a new one fitted but first i will try and clean the area and re-seal if this stops then I know for certain its the windscreen. Any tips on whats best to use to remove the sealant Quote Link to post Share on other sites
vr6freak 3 Posted January 8, 2021 Report Share Posted January 8, 2021 It’s running down from behind the dash. On the drivers side it’s coming from above where your accelerator pedal is. On the passenger side it coming from the right side of the floor pan. ( where your right foot would be if you where sitting in the passenger seat) I will post some pics when the screen gets cut out. Quote Link to post Share on other sites
Harry-vr6 30 Posted January 8, 2021 Author Report Share Posted January 8, 2021 It’s running down from behind the dash. On the drivers side it’s coming from above where your accelerator pedal is. On the passenger side it coming from the right side of the floor pan. ( where your right foot would be if you where sitting in the passenger seat) I will post some pics when the screen gets cut out. You sir are a legend! And you are correct i only have the issue on the driver side. I resolved the passenger side, my scuttle tray was split at the bottom therefore it pissed water in from the heater blower through the pollen filter. Quote Link to post Share on other sites
