Trev1991
Clutch return spring
Looking at fitting a clutch return spring to my 1993 vr6 as it didn't have one on when I bought it. Had the slave cylinder replaced as pedal was on the floor. Clutch now works but does not spring back to the correct position. I have ordered the spring but feel I need a plastic clip that sits in the slot on the bulkhead. Any ideas what this part is called or a link to where I can find one, cheers.
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F161480005277
If that is the part you have bought there is no more parts to it.
Looks same as the one i had to refit on my mk4 1.8t after the pedal broke. Quite tricky to get lined up, the white end goes onto the pedal and the grey part rests in a recess on the pedal box.
Upside down with head looking up from the pedals is the only way in. I cable tied mine to create some space, but in the end it was a combination of fingers and a screwdriver pushing down on it that got it seated.
Probably some luck too, was a pain in the backside and neck
