liam.1995 1 Posted August 24, 2018 Report Share Posted August 24, 2018 Hi guys. Finally got the golf running after rebuilding the engine and having trouble starting the car. It will start on the second/third turn of the key. Worked out the fuel pump isn’t priming and not to sure if it is running after start up. Checked voltages at the relay and I’m only getting 2-3 volts to switch the relay!!! If I link out the terminals for the pump the pump will run. So I’m pretty sure the pump and wireing is sound. Does anyone one know what voltage I should have to switch the fuel pump relay???? And where does this come from???? Link to post Share on other sites
Philly-R6 28 Posted August 25, 2018 Report Share Posted August 25, 2018 The A2 resource site is your friend:http://www.a2resource.com/electrical/CE2.html The fuel pump relay is in the fuse box housing position 12 - bottom right. The fuel pump is between pins M/01 (0v) and M/02 (switched 12v via Fuse 18). The ECU activates the fuel pump by making pin 6 on the ECU low. This energises the fuel pump relay passing 12v to the fuel pump. Link to post Share on other sites
liam.1995 1 Posted August 25, 2018 Author Report Share Posted August 25, 2018 Hi thanks for the reply. Do you know where cable 15 comes from that goes to the coil on the relay??? Link to post Share on other sites
Philly-R6 28 Posted August 25, 2018 Report Share Posted August 25, 2018 Those identifiers are standard. 31 is battery -ve 30 is battery +ve 15 is ignition - by turning the key X is load reduction - essential bits, while cranking the starter Link to post Share on other sites
