barrie culley
02A close ratio race gearbox, Gripper LSD, large flanges.
This is a VW 02A close ratio racing gearbox from the Vento Challenge Championship.
The gear set was supplied by Gemini as per the Vento Challenge specification with standard 1st & 2nd and close ratio 3rd, 4th and 5th.
It has Gripper LSD which has only been run for 2 hours.
Large flanges have been fitted which use the larger fixing bolts for additional bolt strength. Flanges are bolted in not push fit for reliability. The matching inner constant velocity joint we used are GKN 302305 which are for VW Caravelle, VW Multivan and VW Transporter. Eurocarparts 657446590.
The gearbox was checked and refurbished by Road and Race but has not been fitted/run since.
A couple of the threaded bolt holes need  helicoil inserts as the threads are worn.
Listed on ebay for £1600
