vr6guy
Can you drive Vrt without map to get it mapped?
Hi all!
I couldn’t find any answers on this... but when my turbo install is done can I drive the car to the tuners so I can get it all mapped?
will have the bigger Maf, injectors etc.. it’s 100 odd mile trip there  :)
Hi all!
I wouldn't of thought so with bigger maf and injectors on standard map/ecu.
I would send the ecu to the tuners to get a base map on it, then you can drive it there for final adjustments on dyno.
General oem map on a mk5 R32T for example will be like this (10psi not 14), "bag o nails" as we call it before it's mapped as so...;
MK5 GOLF R30 GT35R
Then sort your fuel mass, can vary depending on mods but as an example;
fuel
Edited by RBPE
p.s. bottom one is a modded HGP file, so different approach, others are actual figures from R32T files I did with the owners!
p.p.s.  You need to do after start and warm up maps etc to get it all tickety boo and run like stock - the references shown on there are from things like Nef Moto calcs etc for reference!
Edited by RBPE
