graham488
Supercharged Vento VR6
Trying to get a rough idea on the value of my R reg ('97) Vento VR6 which I bought as a project car approx six years ago. I would be looking to include the donor car (P reg '97 Golf VR6), along with some new and second hand parts in the valuation.
I have come to the realisation that I simply don't have the time to commit to this any more (work, two small children etc etc) and while I appreciate that   the value of some components individually might be reasonable, I just don't have the time to strip these out and suspect the value may be reduced as a result. Anyway here's what I've got......
Vento VR6 R reg Sept 1997
approx 177000 miles
mystic blue pearl
MOT'd until May 19th 2018
Vortech VF9 supercharger running about 7psi making 254bhp
16" mk4 golf BBS split rim cross spoke alloys (require refurbished)
mk4 golf GTI 288mm front disc and calliper set up
sunroof
Climatronic air con
lowered suspension
bodywork condition is not great - n.s.f. wing badly corroded, n.s.r. quarter has a dent in it, a few other bits of rust, o.s. & n.s. sill plastics require replaced
The donor Golf has given up the following to the Vento......
100k mile engine (which had the head gasket, chains, tensioners and water pump replaced by me before fitting)
gearbox
front bumper
bonnet, grill and head lamps
starter motor
floor sound deadening and carpet
full cloth Recaro seats inc rear bench
n.s.r door, quarter window
n.s.f. door
VW Golf VR6 P reg March '97.
Was bought to provide above parts to the Vento, so is partially stripped but unused removed parts have been kept - drive shafts, eng ecu etc.
100000 miles
mystic blue pearl
sunroof
towbar
SORN'd
Eibach front and rear anti roll bars
Koni lowered suspension front and rear
17" straight spoke alloy wheels
Second hand parts.........
170k mile OBD2 VR6 engine inc - manifolds, injector rail etc
110k mile OBD1 VR6 engine - chains jumped, so valves u/s Head is off and valves removed.
VR6 gearbox - parts only as casing has been smashed by a self destructing diff
VR6 exhaust CAT
New parts.........
genuine VW o.s.f. wing with side repeater hole
genuine VW n.s.f. wing with side repeater hole    without aerial hole
genuine VW o.s. sill
genuine VW complete set of o.s. & n.s. plastic sill trims inc all clips and screws
genuine VW inner door foam liners  x4
Ive probably forgotten some stuff, but just ask if you have any questions.
Many thanks for your help,
Graham.
