jayvwvr6 0 Posted July 11, 2005 Report Share Posted July 11, 2005 as tital suggests,when i use my vw touch up paint it always looks,well,touched up and crap!and what you supposed to do with the clear laquar paint?when i add this on top of the touch up it looks even worse,are you supposed to flat it down with a very light wet and dry?after the base coat? Link to post Share on other sites
Nerih 0 Posted July 11, 2005 Report Share Posted July 11, 2005 i've tried it so many times, and given up, it just ruins the paintwork, i've only used it on bumpers mind you, i'd never put it on the metal paintwork, bumpers can be replaced easily... Link to post Share on other sites
binliner 0 Posted July 11, 2005 Report Share Posted July 11, 2005 if you have stone chips you can kind of fill them with a drop of paint then a drop of lacquer when dry and give it a real light rub with some fine wet n dry before polishing it up Link to post Share on other sites
purple highline monster 0 Posted July 12, 2005 Report Share Posted July 12, 2005 clean the chip if its a bad one even with a bit of cure rust if its bare metal , then apply the basecoat (if its mettalic) and leave it to dry a few days, once you have covered the chip it stops the corrosion getting in and then you can "build" the paint back up and then put the laquer layer on once its all dry, & give it a polish, the trick is not to rush the job and it will look 10 times better but never perfect! it just helps take the eye off any obvious chips usually on the biggest flatest panel!! the bonnet! Uuuuggghh Link to post Share on other sites
stockers 1 Posted July 12, 2005 Report Share Posted July 12, 2005 :| Link to post Share on other sites
uber-tub 0 Posted July 12, 2005 Report Share Posted July 12, 2005 1200 - 2000 wet n dry (very wet) and a good mop and polish. Use one of your lass' tiny weeny lipstick brushes to put the smallest amount of paint in (should put you in the good books).This should just about knacker your paint, but if you're patient you might pull off a decent job... so to speak. Best to get a body shop to airbrush it and cut it back. Link to post Share on other sites
vr6madmike 0 Posted March 5, 2006 Report Share Posted March 5, 2006 I wouldnt use ultra deep shine i used some and the car comes up extremely shiny unti u get the sunlight on it and see all the swirls on it I think its too harsh for my mustic blue pearl paint ive gone back to using super resin polish and then the extra gloss protection and extremely clean dusters! Link to post Share on other sites
stockers 1 Posted March 8, 2006 Report Share Posted March 8, 2006 http://www.autopia-carcare.com/inf-paint-polish-clinic.html if you scroll down the page it shows step by step guide on how to remove scratches, the same will apply to stone chips i guess Link to post Share on other sites
St. Ouens 0 Posted June 19, 2006 Report Share Posted June 19, 2006 awesome article. mind you, just made me more inclined to take it to a decent paint shop!! Link to post Share on other sites
vdubgirl 3 Posted June 21, 2006 Report Share Posted June 21, 2006 For stone chips I use a pin and paint! Dip the pin into the paint and let the paint drop into the stone chip - Works a treat! Link to post Share on other sites
andy 0 Posted June 21, 2006 Report Share Posted June 21, 2006 Brilliant article, really liking that stone chip idea too. :-) Link to post Share on other sites
