Vrt cylinder pressures?
I'm in the process of trying to solve a running issue with my vrt and Ive done a cylinder pressure test to rule any headgasket/ piston ring issues  test was done with engine upto temp and I'm running a spacer to make comp 8.5.1
All cylinders were between 100-110 psi , is this ok as I know what psi it states in the Bentley but this is for a standard compression vr and I'm hoping my figures are ok due to lowering the compression of the engine for going turbo
cheers Neil
Been running rich but I think I've narrowed that down to a warped flange on the turbo to manifold adapter I made letting some gasses out
I just wanted to double check the cylinder pressures are all good as I've taken the car off the road to freshen everything up and it would be easier to do any work on the engine when it's removed
the head wasn't rebuilt but was skimmed when removed for fitting the spacer and new stem seals were installed and the engine has covered 116,000 miles
That works out at 125 psi with the 8.5 to 1 ratio you are running
That's if we take the lowest acceptable stock compression of 145 psi. So your compression is a bit down. I always inspect and regrind the valves in when the engine milage is more than 100,000 that could make a difference to your compression
If not it's got to be the ring's
A leak down test is the way to go to determine where the compression is going
Cheers for the replys mate from what I read  in the Bentley the stock compression figures when new are 160-189 psi with a wear limit of 109 psi, either way I'm still right on the limit
sorry forgot to say I also cleaned the valves and lapped them in
ill look into into doing a leak down test
