Will edit soon, new layout;
Main torque maps in the ecu's, KF (kenfelder - map, M - moment/torque) - are KFMIOP and KFMIRL - essentially the main torque maps for the central torque monitoring ecu's - some locations and info (to be edited);
Note - 022906032 is the usual ecu number for ME7.1.1. - BG is the commonly used BDE code between tuners, 032E is the one often used for AUE none twin vvt ecu's, will update with more info when needed;
BDE v's a tuned HX35 turbo AUE;
KFMIOP BDE v AUE Turbo
Notice how the AUE turbo has IOP modified to be maxxed at any load over 100% - the stock limit of a naturally aspirated engine.
If you look at this AUQ ecu of mine v a V6, you can see load variances;
IOP AUE Turbo v AUQ 20vt
You can see the stock iop map maxxed on the AUE Turbo, basically telling the ecu to follow x (nigh on 100% torque) over the usual 100% max value of ambient pressure as there is no way of measuring boost, whereas the 20vt ecu accounts for this with a load past 100%, 160%  in this case.
Stock AUE
IOP AUE Stock v BDE
Hybrid and supposed BFH from DAMOS packs;
IOP Hybrid BFH v BUB Turbo
BUB v BUB Turbo.
IOP R32 BUB Turbo v BUB Stock
Then KFMIRL or IRL tuning which are (sort of) inverse maps, loads of threads online, will talk about them as we go on;
BDE v AUE Stock locations and AUQ;
IRL AUE Stock v BDE
BFH v BUB Turbo;
BFH Hybrid v BUB R32 IRL maps
BUB v BUB files; (032CE code)
BUB v BUB Turbo IRL Locations
Will edit as needed, you can follow a lot of how these are tuned (minus the boost), here;
https://s4wiki.com/wiki/Tuning
Edited by RBPE
Some links;
You can use files from here to build your own definition file if you haven't got flashing tools yet; I'll probably use them for demonstration purposes.
http://www.chip-tuner.hu/original_ecu_files/files/VW/
I don't use it myself commercially, but the winols demo is good to learn on here;
https://www.evc.de/en/download/down_winols.asp
Free hex editor here;
https://mh-nexus.de/en/hxd/
Most make xdf files to use Tunerpro for tuning, which can be found here;
http://www.tunerpro.net/
Cheapest standalone checksum checker;
https://www.ecufix.com/shop/index.php?main_page=product_info&cPath=2&products_id=180&zenid=ervbr1d371a90kcnohotedo015
However, checksums can be sorted out in some of the newer ebay based flash tools like MPPS v18 onwards, which means you can now essentially tune your car for less than £100 all in.
These can also be used on DSG;
http://www.obdexpress.co.uk/wholesale/2014-mini-dsg-reader-dq200-dq250-vw-audi.html
Edited by RBPE
