2003 2.8 24v VR6 angle sensor fault
You need to calibrate the sensor for the light to go off, you can do it with your vagcom or I could do it with my snap-on solus.
So I did calibrate the angle sensor and finally the light shut off. But now after I drive my car for a couple of min the light turns back on. Now from my understanding if the steering wheel is centered it should be showing that it's zeroed out? Well my steering shell is only zeroed out when it's slightly turned left.
