V64motionjsy 0 Posted December 18, 2016 Report Share Posted December 18, 2016 (edited) I have had several issues recently with my car. Stick coils plugs and crank position sensor were replaced about 5 months ago but I still have running issues, took it to a friend who checked the fault codes first, cleared them then re checked to see what gremlins were still lurking under the hood. Turns out that there is a cam position sensor problem. Does this car have two like the vr6 motor or just one. The reason I ask is the parts supplier I used said that going by my chassis number it only had one but it looks very similar to the vr6 motor which has two. I have looked high and low for a free downloadable manual online but can't find any which cover this model. Edited December 18, 2016 by V64motionjsy More info added Quote Link to post Share on other sites
RBPE 198 Posted December 22, 2016 Report Share Posted December 22, 2016 Early 24V's inlet cam timing only, later ones inlet and exhaust cam timing, sensor accordingly! V64motionjsy 1 Quote Link to post Share on other sites
mattvr6 133 Posted December 26, 2016 Report Share Posted December 26, 2016 It is a vr6 Quote Link to post Share on other sites
V64motionjsy 0 Posted December 26, 2016 Author Report Share Posted December 26, 2016 V6 4motion mk4 2002 Quote Link to post Share on other sites
RBPE 198 Posted December 27, 2016 Report Share Posted December 27, 2016 (edited) Check the engine code - BDE twinny for example; http://www.oemepc.com/vw/part_single/catalog/vw/markt/RDW/modell/GOLF/year/2003/drive_standart/405/hg_ug/109/subcategory/109090/part_id/3723592/lang/e AQP/AUE Single VVT to 2001, BDE twin VVT 2002 - check engine code for dates around there to see which or part differences; http://www.oemepc.com/vw/part_single/catalog/vw/markt/RDW/modell/GOLF/year/2001/drive_standart/203/hg_ug/109/subcategory/109045/part_id/3691323/lang/e Edited December 27, 2016 by RBPE Specifics V64motionjsy 1 Quote Link to post Share on other sites
V64motionjsy 0 Posted December 28, 2016 Author Report Share Posted December 28, 2016 My engine is a BDE Quote Link to post Share on other sites
mattvr6 133 Posted December 29, 2016 Report Share Posted December 29, 2016 Yea it is a vr6 that's why it looks the same! What fault code is coming?correlation fault? Is it running rough? Quote Link to post Share on other sites
mattvr6 133 Posted December 29, 2016 Report Share Posted December 29, 2016 It has 2 cam sensors 2 vvt solenoids and 2 cam varitors, Quote Link to post Share on other sites
V64motionjsy 0 Posted December 31, 2016 Author Report Share Posted December 31, 2016 Would love to get hold of some pictures of where these items are situated, there doesn't seem to be much info available on this car Quote Link to post Share on other sites
V64motionjsy 0 Posted December 31, 2016 Author Report Share Posted December 31, 2016 It came up with cam position sensor fault, didn't say which one Quote Link to post Share on other sites
V64motionjsy 0 Posted December 31, 2016 Author Report Share Posted December 31, 2016 On 29 December 2016 at 11:42 PM, mattvr6 said: Yea it is a vr6 that's why it looks the same! What fault code is coming?correlation fault? Is it running rough? Yes it is running rough, changed a cam sensor and seemed to improve a bit but still sounding like a diesel at idle, runs better at higher revs. Quote Link to post Share on other sites
mattvr6 133 Posted December 31, 2016 Report Share Posted December 31, 2016 Sounds like timing chain if it's noisey, I'll post a pic of my car when I'm back home so u can compare, vvt solenoids make it run rough on idle, if u can get hold of Vag com u can check chain stretch in channels 108/109 anything more than -10 kw chains need replacing Quote Link to post Share on other sites
RBPE 198 Posted January 2, 2017 Report Share Posted January 2, 2017 (edited) On 31/12/2016 at 11:17 AM, V64motionjsy said: Would love to get hold of some pictures of where these items are situated, there doesn't seem to be much info available on this car I've just given you links to all the parts and pictures above! 20, 21, 24 etc here; http://www.oemepc.com/vw/part_single/catalog/vw/markt/RDW/modell/GOLF/year/2003/drive_standart/405/hg_ug/109/subcategory/109090/part_id/3723592/lang/e What codes exactly is it showing too? http://forums.ross-tech.com/showthread.php?360-Troubleshooting-P1340-Camshaft-Position-Error Edited January 2, 2017 by RBPE Quote Link to post Share on other sites
mattvr6 133 Posted January 2, 2017 Report Share Posted January 2, 2017 Don't show cam sensor tho 24 is the vvt solenoid Quote Link to post Share on other sites
RBPE 198 Posted January 3, 2017 Report Share Posted January 3, 2017 It'll be there somewhere, it's the entire car, probably just in a different area ifyou go through the menu, for example; http://www.oemepc.com/vw/part_single/catalog/vw/markt/RDW/modell/GOLF/year/2003/drive_standart/405/hg_ug/906/subcategory/906000/part_id/3726195/lang/e http://www.oemepc.com/vw/part_single/catalog/vw/markt/RDW/modell/GOLF/year/2003/drive_standart/405/hg_ug/919/subcategory/919050/part_id/3708908/lang/e Quote Link to post Share on other sites
