mk2redvr6
Dzl v5 gearbox
Hi guys
Just a quick one
I have a mk2 vr6 and at oulton park the other week I broke my mk3 vr6 gearbox
I have a v5 dzl gearbox which am fitting
Just a couple of question
At the moment am running a cable clutch conversion which I want to keep .can the dzl run the clutch cable conversion ?? Also does the vr6 starter motor work ok or do I need the v5 one . also am running 4 x100 hubs Not wide track . do I need to change the drive cups or drive shafts
All help is welcome
Thanks guys
The cups are the bokt on type on the DZL box, so you can run 100mm or 108mm cups.. whichever match ur shafts.
The starter has 1 hole that needs drilling out iirc if u keep the vr6 one, otherwise the v5 will do fine but u need the bolt then as its threaded I think.. been a whike since doing mine, but its pretty much identical.. would reccomend a diesel 5th though..
