wisby 6 Posted March 8, 2017 Report Share Posted March 8, 2017 Best bit I think they were only £7 each. Link to post Share on other sites
boab3 164 Posted March 8, 2017 Author Report Share Posted March 8, 2017 What was your reasons for not keeping the seals both the same.as i can use both seals the same i think they are 35mm od 17mmid Link to post Share on other sites
wisby 6 Posted March 8, 2017 Report Share Posted March 8, 2017 They weren't then we took it apart. Link to post Share on other sites
boab3 164 Posted March 8, 2017 Author Report Share Posted March 8, 2017 Ouch someone must have machined impeller side out maybe due to bearing failure maybe damaged housing.have you used angular contact bearings? Link to post Share on other sites
wisby 6 Posted March 8, 2017 Report Share Posted March 8, 2017 As far as I know there the original ones the inner diameter is the same. It's just the od are different where they sit in the collars on the housing. I used the 3 bearings that were in the rebuild on hear . VR6Pete 1 Link to post Share on other sites
boab3 164 Posted March 8, 2017 Author Report Share Posted March 8, 2017 Funny as if you look at my 1st post i had 2 bearings with a spring loaded coupler Link to post Share on other sites
wisby 6 Posted March 8, 2017 Report Share Posted March 8, 2017 That's what mine was like boab3 and VR6Pete 2 Link to post Share on other sites
boab3 164 Posted March 9, 2017 Author Report Share Posted March 9, 2017 Mines both sides of housing the same diameter for seals.ive no locking ring like that.weird why they made so many different.all i have is 2 bearings one spring loaded coupler and 2 locknuts on the main shaft for retaining the bearings Link to post Share on other sites
boab3 164 Posted March 9, 2017 Author Report Share Posted March 9, 2017 Whats the small seal number/details you have as id be aswell buying 2 of them as my housing takes seals the same size Link to post Share on other sites
boab3 164 Posted March 12, 2017 Author Report Share Posted March 12, 2017 May have found a good quality seal just need to check the depth of the housing for the seal sealing on the shaft.Look at this on eBay http://www.ebay.co.uk/itm/162320798265 Link to post Share on other sites
relik 0 Posted April 3, 2017 Report Share Posted April 3, 2017 I have two ZR1 chargers that I'm looking to rebuild. In the U.S. the cogged pulleys on the ZR2 were apparently pretty rare due to a ProCharger patent. Does your machine shop friend have any interest in making more shafts to sell? Did he also make the small cogged pulley or is RUF selling those now? Link to post Share on other sites
boab3 164 Posted April 3, 2017 Author Report Share Posted April 3, 2017 These pulleys are on ebay for £10 they do need machined out to fit on the supercharger shaft.as for the shaft it was a one off but i can measure up the shaft dimensions and post it up for you VR6Pete 1 Link to post Share on other sites
boab3 164 Posted April 12, 2017 Author Report Share Posted April 12, 2017 Brace fitted just awaiting seals for charger had to modify housing as seal on charger sits too low on shaft so getting collars machined up to lift seal upto sealing area on shaft. VR6Pete 1 Link to post Share on other sites
boab3 164 Posted April 16, 2017 Author Report Share Posted April 16, 2017 Well charger housing with my machinist mate need to lift seal to get seal onto sealing area of shaft hopefully machining up a top hat collar to lift the viton seal im fitting to seal on shaft.in the meantime ebay goodies againNice billet dipstick on its way Link to post Share on other sites
wisby 6 Posted April 21, 2017 Report Share Posted April 21, 2017 Getting a bit cheesed with mine . All the seals are holding up. It's now weeping where the two housings go together. What map and fuel pump are you using with these things My car was at 8v gti so I'm not sure if that pump is up to it really so I'm going to replace it with the 16v kr one. Link to post Share on other sites
boab3 164 Posted April 21, 2017 Author Report Share Posted April 21, 2017 My chip i got is allready mapped for stage 1 charger distributor model its a united motorsports chip.but id prefer to have a rolling road map.im fitting a mk3 golf tank i do have a 16v pump and housing etc from a mk2 wasn't sure if it would supply enough on full throttle Link to post Share on other sites
boab3 164 Posted June 3, 2017 Author Report Share Posted June 3, 2017 Theres not much room anywhere with a charger on Good bye knuckles. this is where I keep mineHey pete where did you get this hose from? Any problem with it collapsing under suction? Ive got it all up and running all seems good maybe a bit rich and lumpy on idle but i think its down to the maf being too close to charger causing turbulence from the impeller Link to post Share on other sites
boab3 164 Posted June 3, 2017 Author Report Share Posted June 3, 2017 Couple of new bits machined up to take the viton seals i bought all fitted and oil leak free been running fine just to move maf further away from charger should solve the idle and running rich issues Link to post Share on other sites
VR6Pete 1,456 Posted June 3, 2017 Report Share Posted June 3, 2017 52 minutes ago, boab3 said: Hey pete where did you get this hose from? Any problem with it collapsing under suction? Ive got it all up and running all seems good maybe a bit rich and lumpy on idle but i think its down to the maf being too close to charger causing turbulence from the impeller I got them from ASH performance mate, they are intended as intake hose and are re-enforced and so not collapse. boab3 1 Link to post Share on other sites
boab3 164 Posted June 9, 2017 Author Report Share Posted June 9, 2017 I got them from ASH performance mate, they are intended as intake hose and are re-enforced and so not collapse. Cheers pete one ordered hopefully here monday didn't help i forgotten to tighten spark plugs up now there tight its much better idle is good starts 1st turn of the key but im going to move maf slightly more away from charger see how it alters anything.so no oil leaks as yet crankcase breather done just fuel pump to swap over and a blast up the road.i have found a 16v fuel pump assembly from an early mk2 in my man cave plan is to remove accumulator fit a barbed connection onto pump and straight swap over with pumps.4 bar regulator allready fitted so fuelling should be sorted.once this rains out the way its time for a road test VR6Pete 1 Link to post Share on other sites
boab3 164 Posted June 18, 2017 Author Report Share Posted June 18, 2017 Running sweet now bit tight moving maf which is down at bottom of bumper oil catch can mounted just pipe to connect up.Cars turned around now in garage to swap over fuel pump thats 2moro's job.Might change out blue temp sensor still a slight richness when hot if i disconnect sensor it runs spot on so maybe cold start just reading too cold keeping it rich not good with big injectors so ill swap that out.never had a blue temp sensor play up when hot only cold starting Link to post Share on other sites
DriVR6s 0 Posted September 12, 2020 Report Share Posted September 12, 2020 Hi first post on the forum just wondering if you still have this charger setup as I need to ask a few questions Link to post Share on other sites
