thenamesdaryl 1 Posted August 3, 2016 Report Share Posted August 3, 2016 the plastic connector that is about 4 inches from the top of the rad, it connects the 2 large hoses and then tees off to the header tank. mine has cracked at the base of the T. it seems almost impossible to find this part online, i see a later hose that was 1 piece, i dont mind buying one of those but wanted to see if anyone has one of these t pieces laying around first, or any other alternative! like this but original vw plastic http://www.urotuning.com/42-Draft-Mk3-VR6-Stainless-Steel-Y-Adaptor-p/42-931-002.htm Thanks Link to post Share on other sites
VR6Pete 1,456 Posted August 10, 2016 Report Share Posted August 10, 2016 Hi mate. Even if you do find one laying around I can gurantee it will be as brittle as the one that presumably snapped on yours. I'm sure if you search on here there are alternative parts from other cars available. However consider the Chinese silicon hoses off eBay. They are cheap and many people on here are running them without issue. Quality is fine and they are cheaper than the draft 42 alloy version. Pete Link to post Share on other sites
