Turbo V6 4motion for sale
Hi guys, my turbo V6 4motion is for sale, my build thread can be found here
http://www.ebay.co.uk/itm/TURBOCHARGED-VOLKSWAGEN-GOLF-V6-4MOTION-BLACK-TURBO-R32-/222193093201?
Description from the listing:
This vehicle has been built without compromise, using high quality parts and components to withstand its power increase while keeping factory smooth running and reliability.  During the conversion, the timing chains were checked for wear using VCDS which showed low readings, well within spec. The chain and guides were visually checked and had very little signs of wear.  The cylinder bores were also checked and were in very good condition with hone marks still visible. I have a comprehensive photo library of the conversion.
The vehicle has had a full service, replacing all filters, engine oil, coolant, gearbox oil and Haldex oil.  It also has full service history and I also have every receipt for each part purchased for the turbocharger conversion and other modifications/maintenance whilst in my possession.
Turbo boost pressure is set at approximately 16psi, with a turbo of this size it is making 400+bhp and is incredibly fast. With the four wheel drive Haldex system easily putting all that power to the ground.
The 18” alloy wheels are Genuine golf R32 wheels, 7.5J wide and made by RONAL. They have also been powder coated black. The battery has also been placed in the boot, to allow for intake and intercooler pipework.
Engine upgrades include:
Stainless steel head spacer to reduce compression
Race grade connecting rod bearings
ARP connecting rod bolts
ARP head studs
T3 turbocharger manifold
United Motorsports 630cc Forced induction tune
Garrett GT3582R ball bearing turbo
Tial 38mm wastegate
Siemens Deka 630cc injectors
Inline Walbro 255lph fuel pump
Turbosmart boost controller
4” MAF housing
Large K&N air filter
2.5” stainless intercooler piping
450mmx227mmx65mm bar and plate intercooler
NGK BKR7E spark plugs
6 speed DRP gearbox
Other modifications include:
Sachs 4 puck sintered paddle clutch and heavy duty pressure plate
Innovate boost gauge/shift light
Innovate wideband Air/Fuel ratio gauge
Innovate Oil pressure/Oil temperature gauge
All three gauges have built in datalogging capabilities for tuning
Aux and USB adapter
Full 3” stainless turbo back exhaust
20mm hubcentric rear wheel spacers
New rear brake pads
Stainless braided teflon -10 turbo drain
Black teflon -3 turbo feed
Black carbon wrapped interior trim
Recently new front tyres
Washer bottle relocated to the rear
The paintwork is in good condition for its age with some stone chips etc. Typical MK4 golf corrosion around the rear boot handle. The central locking on the rear passenger door needs attention
MOT expires May 2017
In my opinion, comparing this car and its performance to the Golf R32 it’s excellent value for money
For any more information please call me (Dave) on 07972188861
Advertised elsewhere and may remove at any time
Cash on collection
Sold as seen
  • 4 weeks later...
