chippy 34 Posted June 4, 2016 Report Share Posted June 4, 2016 Currently sorting out the wiring in my mk2 vr6. Im using the mk3 VR6 fuel tank, however the plug off the loom doesn't fit the vr6 fuel pump Although both are four pins, u can see the grooves on the plug doesnt match on the fuel pump. Have i missed something here or does anyone have the plug i need? Thanks Link to post Share on other sites
boab3 164 Posted June 4, 2016 Report Share Posted June 4, 2016 Get a plug from mk3 cut and solder to existing mk2 loom.how did you find fitting the mk3 tank?was it an easy fit? Link to post Share on other sites
VR6Pete 1,456 Posted June 4, 2016 Report Share Posted June 4, 2016 My mk3 tank went in a treat on my old mk2. If you have a terminal removal tool just remove the plug off terminals and fit the VR6 one save messing with soldering iron near a fuel tank Link to post Share on other sites
CustomJ 2 Posted June 5, 2016 Report Share Posted June 5, 2016 I found this issue today actually. I swapped the plug for the VR6 one. The wires are the right colours, but the pins are different sizes so you can't swap them over. -J VR6Pete 1 Link to post Share on other sites
chippy 34 Posted June 6, 2016 Author Report Share Posted June 6, 2016 Thanks for the response guys On 04/06/2016 at 8:30 PM, boab3 said: Get a plug from mk3 cut and solder to existing mk2 loom.how did you find fitting the mk3 tank?was it an easy fit? Fairly straight forward, getting the tank straps on where a pain. Also, lining up the fuel tank neck to fit nicely behind the fuel filler cap. Link to post Share on other sites
boab3 164 Posted September 25, 2016 Report Share Posted September 25, 2016 What did you do with fuel pump accumulator box under the car? Link to post Share on other sites
CustomJ 2 Posted September 26, 2016 Report Share Posted September 26, 2016 Got rid of that. You don't need it. If you are using the mk3 lines there is a fuel filter under the car instead. Use that. -J boab3 1 Link to post Share on other sites
boab3 164 Posted September 26, 2016 Report Share Posted September 26, 2016 I'm sticking with mk2 lines just have to mod feed line under car to take in line filter in place of accumulator box/pump Link to post Share on other sites
