Hi All, trying to get and idea of what EGT's people are running?
i have been fiddling with the ECU on mine as i was getting AFR of 12.5-14 while cruising, i am now getting close to stoich but my EG temp is up around 850-900c, is this right?
any guidance gratefully appreciated.
cheers
steve
85-90c I guess you mean.
900c the head would melts lol.
Aluminium melts at 660c
Mines about 80-87c depending on out side temp.
When giving it some, raises to about 93-95c after a per longed period.
Don't think I have ever seen mine over 97c
Even on a boiling hot day.
I do have aftermarket electric uprated fans.
Edited by c00k
850-900 isn't too bad, just watch it doesn't climb too far past 1000 on boost.  Try adding a bit more cruise timing if you want the egts a bit lower.  For example, on my VR Turbo with flat top 8.5:1 forged pistons, I was able to run 40 deg advance at low loads at 80ish mph.  That knocked the EGTs down a bit.   Stock timing is around mid 30s up there, but is 10:1 CR.
There's a fine line with EGTs.  Running rich can increase them, running too lean can increase them, you just need to find the sweet spot with the right AFR and timing.
