98 Golf estate >> VR6 build
Hi.
I made a hello post in New Members http://www.vr6oc.com/forum/topic/46077-hi-new-bristol-member/#entry434835 which started to generate useful information, so by starting this new thread I can: 1) keep all information about this kind of build in one place for myself and others, and 2) document what Ive done (compared to what I have planned). Id like to see this thread follow the whole process.
Im a product designer, so whilst I consider myself at least partly methodical and critical, Im no mechanic. Im hoping that method and common sense will get me through, but predominantly advice from here. Probably naive, but you live and learn. So, after a few months perusing the web I bought a 98 Mystic Blue 1.8 estate with 76k and 11months test in January as a base car, with full intentions of going VR6. That wont change, Ive never owned anything other than a 4 pot car wise.
The research began and still continues - kinda fun, I enjoy exploring possibility and feasability. I started to get an idea of what I wanted as an end result - OE styling, Euro-esque, refined and well considered. Im not changing anything for the sake of it. Am I taking it too seriously? Maybe, but I want to enjoy my car.
So here's a 'living' to do list, PLAN A, Ive generated from research and personal taste. I say 'living' because it changes...frequently. I may add lasers at some point. I do bits and pieces when I have time and plan to do the conversion this year. It had a damp drivers footwell when I bought it so did a few little fixes to track it down. At the moment Ive traced it to the bonnet release cable grommet. Also the drivers lower door hinge has dropped so Ive painted a new one ready to go on this weekend.
Door hinge dropped - replace with new, painted, re-align door
Saggy drivers door handle - replace spring if poss
Windscreen seal - get checked
Paintless dent removal (about 1 in every panel, no rust though) and bumper repairs, full detail after conversion
Window guide seals
Door membranes - repair
New soundproof front floorpan
Headlining torn and dropped - re-upholster
Cracked N/S headlight - replaced & swapped level motor
Find leak / re-seal grommets in bulkhead - found to be bonnet release cable
Take carpets out - dry
Central locking pump - check
Clean inside arch liners - compost / rot
Floor pan - check and clean
Clear sunroof drains - cleared
Clean windscreen drains
Scuttle panel pins - replaced
Scuttle tray - cleaned out
Pollen filter - new
Bumper O/S grill - replaced
PLAN A
Engine
AAA OBD2
Brakes
280mm (G60, early Gti/VR6) 4 stud (not 288mm 5 stud)
Wheels
16" to clear 280mm brake upgrade - BBS, Borbets? Now found 15" that will fit over 280mm disc (25/2/15). Need estate clearance advice on rim width and ET. No rolled arches here but not looking to run 9j, prob 7j all round.
Suspension
Estate specific coils probably TA. Needs to be drive-able daily.
So, that's my starting point. Any advice, input, constructive crit welcomed that may change the plan. If you can see something in the future that I have not accounted for and may bump into, Id appreciate a heads up early.
Oh and whilst Im already informed it'd be easier with a donor car, I really dont have the space. Im also not confident I'll find the engine and box I want, already in a car, thats being broken up. Im open though. I quite like the idea of generating a shopping list, and Im not in such a hurry to make compromises on the important parts.
Phew, cheers all.
Edited by pappers
  • Replies 84
  • Created
  • Last Reply
Top Posters In This Topic
Popular Posts
Bit of an update..     Full BDE engine 73k.     VR6 base loom for MFA and got passenger airbag.     Clocks and ECU     VR fuel pump, all the Mk3 VR parts came from the same donor car.     Heres m
Off to fetch the engine, looms, ECU, Dbw pedal today. Ive got most of the conversion parts now (he says!). Fuel pump and exhaust still need sorting. Looms wont be done till poss Sept though as the cha
Front 3/4 standing shot...its raining. Coilovers and wheels fitted, still need to get tracking done and a spacer on the rear. Had dents removed, mopped and detailed, now needs a wash. And an engine ch
Im not set on ABV but its marginally choice 1, equally I'd go with a decent OBDII AAA. My thinking is more 'why not ABV 190bhp over 174bhp?' since its not significantly more work to convert, unless Im missing something. Id be swapping the same parts essentially, 2.8 or 2.9. I guess whichever engine is found first in well maintained condition.
Edited by pappers
Got a seized 6mm grub screw in upper door hinge, not annoying, the lower one is fine. Off to body shop to see if they can help removal. To cheer myself up I spent a few pennies on a couple of bits, so pics to follow.
Nearly bought a set of wheels too, but didnt in the end. The process though reminded me that I really want 15s. I drafted 16s originally to clear the 280mm caliper but have since found a few 15s that also clear, and one style that I love and is generally only available in 4 stud.
Made a few changes to the plan, crossed out in original post. After advice on here and elsewhere Im gonna stick with the AAA OBD2, by way of a straight donor car.
Booked mine in for a day of PDR and touch up in a couple of weeks. Interested to see how straight it comes out.
Edited by pappers
Looking good buddy, be much better with the coilovers on.
Gewindedampfers just means threaded damper in English. The make is TA technics. :)
They'll look better on than they do in the box in the garage. :)  Fitted soon hopefully, would be nice to have some rims to go on with them.
Yeah I know :) Im not sure Id have bought a brand called 'Coilovers'. TA seem to be the popular choice.
So I forgot to post pics of fitted coils and wheels but its sitting nice, Im happy. Its gone into the body shop for dents, a full mop and touch up chips, fitting 2 new rear window guide seals and my new drivers door hinge pictured above. Will get pics up on Friday when I get'r back.
I have a few questions about the VR swap.
1. I currently have no ABS and I dont really want it. Ive read this can be deleted upon installing a VR, so is this right? Is it a bodge, can it be done properly without compromising anything? How about MOT/legality wise? Any infos on this would be appreciated.
2. I have power steering already. Do I need to change anything in the system for a VR install or will my current pump etc be ok? Ill try and find part numbers for both cars but if anyone knows from experience it would be helpful.
3. I have a factory immobiliser....so yes, the key and transponder ring question. I want to keep my own key but I also want the factory immobiliser, not an immob delete. Im guessing there are folks who can recode a VR ECU to read my current key? Ive heard the ECU can be made virgin so that the first key it reads is the key it codes to? Right/wrong? Legality? This is in case I cannot go the donor car route and the ECU and ring aren't matched. Either way Id like to keep my current ignition/door key setup, how to do this?
Cheers for the help.
Chris.
ABS not a problem just don't wire it up and tuck the wires away, for mot it will be fine so long as it can pass the brake test. If it passed last year on brakes should be fine this year so long as the brakes have degraded over the last year. How well it stops a VR is another story, as there most probs only 256mm.
I have 288mm and want to upgrade to 323mm for better braking, but that's all down to personal preference.
The power steering rack and parts mounted to the subframe will be fine. The power steering pump should come on the VR engine and you will need to use the VR one as it's connected with the VR belt. Some of the piping might need to be changed, so it can be linked to the Vr pump. As it most probs in a different location after engine swap.
Immobilisers I know you can get companies who can delete them if they can make them virgin I'm not sure.
Edited by c00k
You could get VR power steering pipes,
Or it's just 16mm I.D nitrile pipe for the one pipe. And a banjo fitting and nitrile pipe to fit the banjo fitting for the other pipe. As the power steering pump has only 2 pipes that come off it.
(Nitrile pipe is oil, grease, fuel resistant)
You might get error codes from ABS but it won't cause the engine any running problems. Or anything else problems. It's it own module inside the programming in the ECU. It doesn't link or communicate with anything else. So it would work fine.
You can get the ABS module deleted from the ECU if wanted. Then no error codes will show.
Edited by c00k
Morning. Woken up with a bee in the bonnet.
Did the front panel with rad and twin fans change at all through model years? Any electrical connector differences between OBDs? I can't find this info. There's a VR being broken very near to me (I already had a couple of parts off it) at good value but its OBD1 and no engine or history, so box, ECU and loom are out. I want to grab parts that are universal to OBD1 & 2, leaving myself a low miler OBD2 engine, loom, ECU and VR box to find either independently or together. I'm at: engine brackets, hydro clutch, front panel...anything else that could help? Thank yous.
Rad are the same.
Think there a difference in the fan between OBD1 and OBD2.
It only the motor and I think they are interchangeable, but there is a difference in fan motors I believe.
AUX (secondary) water pump are same for both.
Main water pump same.
Power steering pump same.
ABS is different between models but can be interchanged with minimal work.
Main differences between OBD1 and OBD2 engines are:
Timing chains.
Throttle bodies and vacuum lines.
Upper inlet manifold.
MAF's.
ECU's.
Edited by c00k
No it's just the plug that are different on the fans I think not 100% sure on that though. So if you chopped the plug off for the fans when buying them. you should be able to re-wire that plug to work with OBD2.
Cars looking sweet with new wheels and some lows :)
Edited by c00k
