Mk3highline 287 Posted May 31, 2015 Author Report Share Posted May 31, 2015 Stuck up north again Need a sump asap Bealieboy and bennyk 2 Link to post Share on other sites
Bealieboy 1,625 Posted May 31, 2015 Report Share Posted May 31, 2015 Sorry about that! Link to post Share on other sites
Mk3highline 287 Posted May 31, 2015 Author Report Share Posted May 31, 2015 Let my brother loose in the car At least he loved it lol Link to post Share on other sites
Mk3highline 287 Posted June 2, 2015 Author Report Share Posted June 2, 2015 Got a new sump yesterday morning with fresh oil and filter Fitted and drove home no problems thank godSpent 20min at home and went to work!! Just dropped car off at garage at the second attempt to fit the mk4 rear calipers with the right banjo fittings this time I hope with the braided lines and change brake fluidThe little space for the chargerThink I'm gonna have to move the oil filter housing and oil cooler Link to post Share on other sites
Mk3highline 287 Posted June 3, 2015 Author Report Share Posted June 3, 2015 What a fec aboutOnly managed to fit new calipers and the rear 2 brake hoses as they the brake pipes are corroded and didn't want to risk it and stack up the bill Link to post Share on other sites
Mk3highline 287 Posted June 4, 2015 Author Report Share Posted June 4, 2015 (edited) Decat fitted(thanks jayz vr) love the popping on over run not too sure about the little extra noise up to 4k and it still goes quiet after 4.5k rpm Edited June 4, 2015 by Mk3highline JayzVr 1 Link to post Share on other sites
Mk3highline 287 Posted June 22, 2015 Author Report Share Posted June 22, 2015 Been stealth and got a fault free ecu got a little extra ignition advance awesome work from vince as usual Just need to decide what to do with it now Bealieboy 1 Link to post Share on other sites
B4VR6 193 Posted June 22, 2015 Report Share Posted June 22, 2015 Nice build Link to post Share on other sites
Mk3highline 287 Posted June 22, 2015 Author Report Share Posted June 22, 2015 Thank youWell mpg has gone up even though been driven enthusiasticlyJust changed spark plugs and all seem really good for onceGot the original ecu back on the car too with the new map So will be selling the other ecu with the current map on to use on a 24v conversion daveyboy 1 Link to post Share on other sites
c00k 435 Posted June 22, 2015 Report Share Posted June 22, 2015 Happy days, So your running on a 24v ECU now? With VVT? Link to post Share on other sites
Mk3highline 287 Posted June 22, 2015 Author Report Share Posted June 22, 2015 Nope standard 12v vr6 ecu that came with car with a new semi mapped chip to understand the signal from the later type cam sensor and cam phase wheel mate no VVT science 1 Link to post Share on other sites
Mk3highline 287 Posted June 25, 2015 Author Report Share Posted June 25, 2015 Well the difference is phenomenal now it's got closed loop and it's not over fueling it's socks off plus the little extra timing would of helped But compared to the standard ignition timing on a 4mo ecu it's pretty mild , so will be safe enough for when the charger goes onNext mission science 1 Link to post Share on other sites
Bealieboy 1,625 Posted June 25, 2015 Report Share Posted June 25, 2015 Nice, haven't got a spare 6b adapter flange per chance have you? Link to post Share on other sites
Mk3highline 287 Posted June 26, 2015 Author Report Share Posted June 26, 2015 Nice, haven't got a spare 6b adapter flange per chance have you? What's a 6b?? Link to post Share on other sites
D11PS 146 Posted June 26, 2015 Report Share Posted June 26, 2015 6 branch manifold Bealieboy 1 Link to post Share on other sites
Mk3highline 287 Posted June 26, 2015 Author Report Share Posted June 26, 2015 (edited) Oh yeah cheerswe can get some made see if there is any others as one offs are a bit more Edited June 26, 2015 by Mk3highline Link to post Share on other sites
science 7 Posted June 26, 2015 Report Share Posted June 26, 2015 Very nice! How does it work?Do you need to tap holes in the plate for the 6 branch or do the holes line up? Link to post Share on other sites
Mk3highline 287 Posted June 27, 2015 Author Report Share Posted June 27, 2015 Plan was to cut the old flange off and weld on the new one But getting 2 of the ports (cylinder2 and5) line up might be a bit tricky Link to post Share on other sites
Mk3highline 287 Posted September 7, 2015 Author Report Share Posted September 7, 2015 No update as not had the car And the summed holidays run me dryBut just mixed/ made some 103 octane fuel and it's done this to the paint on the Jerry canBest not spill any lolOn the zafira the turbo spooled up lot sooner and quicker (less lag) and it didn't pull any timing on over boost so was a little quicker I'm not expecting any gains on the golf but seeing if it will burn/melt through any of the fuel lines or kill the pumpPoured it in this morning so see what it does this afternoon Link to post Share on other sites
Mk3highline 287 Posted September 9, 2015 Author Report Share Posted September 9, 2015 No leaks so far and car is even more responsive and no leaksJust done some more with a 3% mix and it's still makes a little difference and mpg is betterMiles better than the methanol just difficult to get hold ofAlso checked front tyres to see how the -2 camber is treating them andHad to get some more tyres and need to get the bushes and toe sorted Link to post Share on other sites
