Dcp1 0 Posted January 7, 2015 Report Share Posted January 7, 2015 Hi what sort of money am I looking at to get my chains replaced on my rado? Cheers Link to post Share on other sites
Vag-hag 147 Posted January 7, 2015 Report Share Posted January 7, 2015 Parts or parts + Labour? Link to post Share on other sites
Vag-hag 147 Posted January 7, 2015 Report Share Posted January 7, 2015 P&L id guess at £800 ish..... I did it myself. Parts were roughly £300 VR6Pete 1 Link to post Share on other sites
Dcp1 0 Posted January 8, 2015 Author Report Share Posted January 8, 2015 I was told around 2.5 hours labour is this about right? Link to post Share on other sites
VR6Pete 1,456 Posted January 8, 2015 Report Share Posted January 8, 2015 I was told around 2.5 hours labour is this about right?If the engine was out of the car on a stand maybe. It's a big job and you are looking at around 8 hours labour. Bealieboy 1 Link to post Share on other sites
Big J 283 Posted January 8, 2015 Report Share Posted January 8, 2015 Chains are a straight forward job, once you get to them. 2.5 hrs is way off the mark unless on a stand as Pete says. It's a while since I've done any but your looking at nearly 2 hrs to get the gearbox out, factoring in brew stops and stress fags. daveyboy and D11PS 2 Link to post Share on other sites
craggsy 91 Posted January 10, 2015 Report Share Posted January 10, 2015 Drive in drive out time would be about 8 hrs I'd say as well. 2.5hrs about right if box off and engine out already Link to post Share on other sites
Dcp1 0 Posted January 12, 2015 Author Report Share Posted January 12, 2015 Ok cheers all suppose it has to be done the rado has 202k Link to post Share on other sites
chazrad 16 Posted January 18, 2015 Report Share Posted January 18, 2015 Its worth doing the clutch whilst your there, so factor the cost of a new one in at the same time. Link to post Share on other sites
Dcp1 0 Posted January 22, 2015 Author Report Share Posted January 22, 2015 I can get the timing chain kit from Ecp for around £165 all in and 8hrs labour at £30 p/h plus clutch so not a cheap job then! Link to post Share on other sites
Big J 283 Posted January 23, 2015 Report Share Posted January 23, 2015 If you can get labour at £30 an hour your doing well! Labour rates across the board average around £65 nowadays. Definitely put a clutch in it whilst your at it. Link to post Share on other sites
