lloydjenks 4 Posted May 21, 2014 Report Share Posted May 21, 2014 Hi guys I was thinking of buying some bbs split rims but they are 8j wide 16" and et25 offset. Would they fit without work or is the offset too much? My cab is lowered 30mm also. Link to post Share on other sites
Bealieboy 1,625 Posted May 21, 2014 Report Share Posted May 21, 2014 I have et 25 on my vr but they're only 7.5 wide. They have a bit of poke on the front but not the rears, I also have slightly stretched tyresSent from my iPhone using Tapatalk lloydjenks 1 Link to post Share on other sites
lloydjenks 4 Posted May 21, 2014 Author Report Share Posted May 21, 2014 Cool thanks for the info. Link to post Share on other sites
Surreyvr6 199 Posted May 21, 2014 Report Share Posted May 21, 2014 Are they a straight fit or are you going to have to have adaptors? Mine are et24 with adaptors, 16x8j on the rear.Sent from your mums iPhone using Tapatalk Link to post Share on other sites
lloydjenks 4 Posted May 21, 2014 Author Report Share Posted May 21, 2014 Straight fit. Link to post Share on other sites
Surreyvr6 199 Posted May 22, 2014 Report Share Posted May 22, 2014 (edited) You will need spacers then, from memory of vr's is et44 so I'd got. For 20mm hubcentric spacersSent from your mums iPhone using Tapatalk Edited May 22, 2014 by Surreyvr6 Link to post Share on other sites
jamesw6810 80 Posted May 22, 2014 Report Share Posted May 22, 2014 spacers will only lower the offset further, if they are 5x100 et 25 they should fit ok, may catch slightly on the rear lips if its fairly low... lloydjenks 1 Link to post Share on other sites
Surreyvr6 199 Posted May 22, 2014 Report Share Posted May 22, 2014 Ah ok, so if you added 20mm that would make it et5? I'm dyspraxic so always get things like this muddled up, thought you added the mm of the spacer/adaptor to the et. If that's the case then yours will fit fine as my 8j rears stick out further, lower than 30mm and I'm on the limit of needing arch work done. It's on the list of things to do so I can get a bit lower Sent from your mums iPhone using Tapatalk Link to post Share on other sites
lloydjenks 4 Posted May 23, 2014 Author Report Share Posted May 23, 2014 Cheers guys your input is always appreciated Link to post Share on other sites
