VR6CABBS 1,311 Posted May 18, 2014 Report Share Posted May 18, 2014 Looking for some info on removing my passenger airbag. Firstly I want to fit a high level glovebox like in the gti. I guess this will be a direct fit but I was wondering if I remove the passenger airbag will all the others still work. Secondly who will be able to re program it so it doesn't reckonise the fault and leave the airbag light on. Any info will be appreciated. ThanksCarl Link to post Share on other sites
Lukey. 381 Posted May 18, 2014 Report Share Posted May 18, 2014 Remove it with the battery off and put a 3 ohm resistor in the yellow plug, done just this and it's fine. Link to post Share on other sites
VR6CABBS 1,311 Posted May 18, 2014 Author Report Share Posted May 18, 2014 Remove it with the battery off and put a 3 ohm resistor in the yellow plug, done just this and it's fine.Cheers for the info Lukey. Where do you buy the resistors from mate? Link to post Share on other sites
VR6CABBS 1,311 Posted May 18, 2014 Author Report Share Posted May 18, 2014 Cheers for the info Lukey. Where do you buy the resistors from mate?Having looked abit further than my nose mate I've found some on ebay. Infact there's loads on ebay. Haha. Buy can't see a 3ohm one. There's 2.7 and 3.3. Which ones best pal??Thanks Carl Link to post Share on other sites
Lukey. 381 Posted May 19, 2014 Report Share Posted May 19, 2014 3.3 should do, I got them just from maplin. Link to post Share on other sites
VR6CABBS 1,311 Posted May 19, 2014 Author Report Share Posted May 19, 2014 3.3 should do, I got them just from maplin.The ones on ebay are fused ones mate with wires coming from them. Is there any pacific way you plug them in?Don't want an explosion in my car when I turn the ignition on. Haha. Link to post Share on other sites
Lukey. 381 Posted May 19, 2014 Report Share Posted May 19, 2014 (edited) That won't happen with a 3.3ohm resistor, they won't even get a slight bit warm, just make sure the resistor legs are stuck right in the plug Edited May 19, 2014 by Lukey. Link to post Share on other sites
Daverse 175 Posted May 19, 2014 Report Share Posted May 19, 2014 Rapid electronics are the best for componentsSent from my GT-I9300 using Tapatalk VR6CABBS 1 Link to post Share on other sites
Daverse 175 Posted May 19, 2014 Report Share Posted May 19, 2014 (edited) Oh amd resistors arent polarised, plug them whichever way you want Although the tolerance band is usually pointed to the ground for ease of reading the valueSent from my GT-I9300 using Tapatalk Edited May 19, 2014 by Daverse VR6CABBS 1 Link to post Share on other sites
VR6CABBS 1,311 Posted July 27, 2014 Author Report Share Posted July 27, 2014 Oh amd resistors arent polarised, plug them whichever way you want Although the tolerance band is usually pointed to the ground for ease of reading the valueSent from my GT-I9300 using TapatalkAll done Dave. Seems to be ok. No lights on so must have done it right. Haha.Cheers palCarl Link to post Share on other sites
