The part numbers on mine at the minute do they need to be the same as a replacement pump and ecu or can you replace with different.......as in the pump and ecu together off a different car to mine, or have the part numbers got to be exactly the same?
thanks
The computer its been plugged in to said it was the rear right sensor and parameters of the pump, changed the rear right sensor and worked for a week, now the light is on and even though the lights on, sometimes the ABS works, most of the time it doesn't.
Just need to know if i need to change the Pump or the ECU or both lol.
Will more than likely be the ecu mate, the ecu can be changed by itself if it matches the pump. Youll need to check the part numbers on the ecu which will need removing to do so, but its fairly easy to do.
Edited by jamesw6810
you can change the ecu for a different number one but you will need to have a specialist who knows what they are doing with vcds or vag-com to have it written back onto your system not sure if you need the pump to match.
Edited by CALICO
I would also like to know, as I need to replace my pump and ecu I want to know. All I have been told is my ecu is 3A0907379e but I have seen quite a few 3A0907379D with different pump numbers. Are they compatible still if they have come off a gti?
