hi all,my vr6 is seriousely lacking under 3500 revs, but when it hits 3500 it kicks in , is this normal as this is my first vr6 and dont have a benchmark to compare with.ive only had it about a month and have changed the air filter and induction back to orriginal vr6(crappy and very noisy pipercross now in the bin)its been on th diagnostics at vw (£14.50)and come back clear. also replaced catalytic converter but it is still backfiring aswell, can anyone help, cheers.
Looking at the enigne, on the right hand side where all the ignition leads plug into ... Its a metal block... Unless yours is an early car and has a distributor cap......in which case its not the coil pack ;-)
im a 90% novice lol as u look from the front i THINK its on the right hand side of the engine (its deffo on the side i just cant remember which lol) its where the leads go ps its plastic not metal
[ Edited Sun May 08 2005, 06:09PM ]
oh right, g + s carry vw ones but recommended non vw but german made, saving around £100.i'm changing the plugs and treating the car to an oil change aswell so will post with results. (i will recieve my bentleys manual in a few days so hopefully will be able to carry out more work myself), cheers
a few have had trouble with the cheap leads. warren aka badboyv6 had a bad experience with some from either gsf or ecp recently.
best to use a genuine filter from vw and synta silver oil seems to be the most popular, again from vw at a good price. you'll need to buy more than the 5litre tub as the engine takes roughly 6 to fill (i think)
is seriously underpowered below 3500?? if its still smooth and just not as quick as you expected then there maybe nothing wrong. easiest way to tell is to get it on a rolling road to check the power output.
Dont get the leads from GSF if you can afford not to- they are crap!!!!! (sometimes you end up with an ok set but its not worth the hassle) Get Magnecor ones- they are 100 quid but come with a 10 year warranty!!!
I bought a set of leads from GSF- and went to RR day 2 weeks later only to find out they were already fooked!...
cheers guys, it is pretty smooth on acceleration, but at low speeds around 30mph and low revs 2000 and under but in gear 4/5 i can feel the car/engine jump or lerch a little, thats what orriginally made me think of plugs and that it was missing a spark??
